Question about Coleman Proforce 6 Gallon Air Compressor
I have the proforce vp0200604. it blows fuses in my garage. no other power tools do this and I have them all. now it wont turn on at all. can I fix it? do I have to have a dedicated line?
No power on my pro team proforce 150xp
Generally a bad switch . We have the replacement fix.
Qualitymro.com
Dec 02, 2015 | Pro-Team ProForce 1500XP Commercial...
Proteam proforce 1500xp machine won't start?
Check the fuse or the or the wire, could be broken
Mar 28, 2013 | Proteam ProForce® 1500XP Bagged Vacuum
Hi I have a coleman pro force air compressor and the fan blade on the motor came lose, do you know where I can get a new one. The center hole is egged out and some of the finns are broke off. The serial #...
This compressor appears to be an obsolete model, and the parts diagram (https://mastertoolrepair.com/air-compressor-parts-vpp0200604-vp0200604-p-14827.html) does not show a part number for the fan blade. This means it was either a subcomponent of another assembly -- probably the pump unit itself -- or it is out of stock permanently. I'd suggest you take the old blade and fill the mounting hole with epoxy, then after it cures, drill a new hole and reinstall it. Otherwise, your compressor is likely "toast."
Dec 26, 2017 | Coleman Proforce 6 Gallon Air Compressor
How do I remove the fuses from my proforce 3000 generator
Hello, I am not familiar with fuses on this model. It has circuit breakers that are on the main electrical outlet panel. These generally are press to reset. If you are experiencing the circuit breakers "tripping" on you, then your load is too great for that circuit. You might have to split loads between all the receptacles. If you are wanting to remove the circuit breakers, in order to keep the circuit supplying power because of the nuisance factor of resetting, then I would advise against it. You might burn out the generator part and this can lead to a very costly failure.
Joe
Jan 09, 2011 | Coleman Powermate Proforce 6,000 Watt 12...
Will not fill with air where can I get parts?
Below is a link for parts to a Coleman compressor model #VPP0200604. Not positive but I think that is what you have.
However before you buy anything how do you know what the problem is? Is the motor running? If the problem is that it's just worn out you may find it difficult to get parts for rebuilding it. What you have is whats commonly referred to as a throw away pump. The second link show the pumps replacement cost, around $85.00. If you do manage to get rebuild parts for it they will cost at least that much.
You can get a Senco at Home Depot which is a couple grades up from yours for around $125.00.
Your compressor is really not worth the effort to rebuild it.
If on the other hand your compressors motor is not starting up please include any details in a response to this and I'll try and troubleshoot it for you.
Hope this helps.
http://www.mastertoolrepair.com/vpp0200604-vp0200604-p-14827.html
http://salestores.com/colema14.html
Nov 16, 2009 | Coleman Proforce 6 Gallon Air Compressor
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
Broken Part. Need Replacement
If you refer to the oil filler plug, item #6 in the diagram linked here, it's listed as obsolete.
If refer to the intake filter, It's item #3 on the diagram, it too is listed obsolete.
I would contact Master Tool Repair at 757-410-2879. They can cross the part to another once they know the thread size of the old part.
Mar 15, 2009 | Coleman Proforce 6 Gallon Air Compressor
Coleman Proforce 6 Gallon Air Compressor Logo
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
