Hi, If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly. if
you dryer is gas check out this gas
no heat
tip.... If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip... heatman101
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is
not being supplied with the proper voltage. Here are three ways to make
sure power is getting to your dryer: First, make sure your dryer is
plugged in. Next, check the circuit breaker panel to make sure all the
circuit breakers are in the correct positions. Finally, check to make
sure no fuses in your fuse panel are blown. Any of these could explain
why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because
its heating element is defective. Heating elements are irrepairable. If
yours has ceased to function properly, you will have to replace it. Open
your dryer's cabinet and locate the heating element so that you can
test it.
