Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Have an old Troy Bilt Horse tiller. The shaft and wheels are moving back and forth from the gear box. The "Slow and Fast" lever is also not engaging. What can I do? The serial # is CH-1001 / 337-Y. Any help would be greatly appreciated. Thank you.
    Genius:
  • 1,416 Answers
HELLO,
from your statement above two things are involve in fixing up your tiller
what you need to do from here is that get your self a set of spanner
to fix up your gear box
peak up the size of spanner that you can use in fixing up the gear
put off the engine then unscrew then remove the old grease in it and then applied some grease oil in it or you should change the gear box completely
if you can not this then for you should be able to use you tiller you have to hold the shaft manually while using it
please note what have been is that your gear box is bad it need service or replacement depending on your financial strength but it is advice to get a new and better one if you can not do the fixing your self
after all this then the level of engaing control will be very ok
Good luck
Posted on May 01, 2010
  • Oloyede Monsuru May 01, 2010
    HELLO,
    completely
    please
    Good luck
Troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Aug 29, 2010 | Troy-Bilt Garden
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Disassemble Troy-Bilt Econo-Horse Transmission (1991 Manufacture)
If you do not have a manual you can get it free at troybilt.com.
Apr 24, 2010 | Troy-Bilt Pony Garden Tiller
Old Troy Built with model #HH60-105106F. What is
That's the engine number. It's a 6Hp Tecumseh. Go on ebay and buy the Troy Bilt parts manuals on CD for Horse Roto Tillers (if that's what it's on). I paid $8. Definitely worth it.
Mar 08, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How does the gear box come apart on a six horse troy built tiller?
  1. Remove belt guard on left side
  2. Remove belt, large pulley on gearbox.
  3. Remove throttle cable, idler pulley cable and shift handle.
  4. Remove engine, handle, wheels, tines cover and tines.
  5. Lay gearbox on side on two sawhorses, left side facing up
  6. Remove all the nuts on that side. If the three shafts have corrosion, use sandpaper to remove.
  7. Pry the two halves apart, then hammer the ends of the three shafts to push through their bushings. Use brass or wood to avoid blossoming the shaft ends. When shafts are through their bushings, the right side will fall away.
Jan 15, 2010 | Troy-Bilt Pony Garden Tiller
What year Troy Built Horse Tiller
The serial number is stamped on the upper right hand side of the gear housing. It is on a flat spot just above the wheel shaft. If it is a newer model it will be on a white sticker on top of the gear housing plate. If it has the T handle it is probably an older 1980's model. If you find the six digit number I can give you the year it was made.
Frank
Aug 03, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
May 24, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
337 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
