Nad reciever it comes on but can't get sound to come out
  • anthonylambe Dec 02, 2008
    I have the same problem no sound on T751... display works.
    No Sound at all..  was working for last few years.
  • 4,234 Answers
The output section is probably in protect mode because a problem was deteceted internally. Please update this with the specific model and I'll try to provide details. Please note that there are variants for a number of NAD receivers based upon the serial number. Please post the serial number as well.
Posted on Mar 25, 2008
How do i hook up my tascam 122 cassette deck to my Nad 7155 reciever i tried
The RCA outputs sockets on the 122 connect to either tape 1 or tape 2 "PLAY". on the Nad.
The Line In Jacks on the 122 connect to the record of tape 1 or tape 2 rec of the Nad.
If you connect it to tape 1 connect both to that.
To listen to the deck you select either tape 1 or 2 depending which you have connected it too.
May 29, 2016 | Tascam Audio Players & Recorders
My nad t753 reciever went into protect mode. i switched it off and was able to get it back into standby mode. The receiver switches back on but no sound comes out of the monitors. I can even switch between...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 31, 2011 | NAD T753 Receiver
NAD 3150 doesn't play any sound
I, too, have the 3150 and have experienced problems with it. With me the INPUT knob is touchy and needs micro turns sometimes to get both channels to come through. Also, it sounds like the pots are dirty as I get a scratchy sound while adjusting the knob. I have been told that these units are great middle of the road audiophile units. Actually, for the price of a used unit you can't do better. I just had an NAD 2400 THX amp delivered today and am using the 3150 as a preamp. My girlfriend is not feeling well and sleeping in the bedroom, though, and I can't listen to it :( The few minutes I heard of Steely Dan's Cousin Dupree made me bout **** myself (until I got the dirty looks). Sorry I wasn't more help! Goooooo NAD!
Jun 30, 2009 | NAD C325BEE Amplifier
NAD AV-716 Surround sound reciever, i need any info about it.
Dear sir
i would like to inform you that I mail you a letter by post and you will received it within two weeks time.
Regarding NAD AV- 716 details and spare part requirement and also i would like to remind you that my second letter stated all requirements etc.dated 8th march 2013. Please refer to the given below Email address.
Thanking you
Your's Sincerely,
Apr 04, 2009 | NAD T761 Receiver
Nad c270 buzzing in amp
The buzzing is coming from the transformer. It is almost expected of an amplifier of this size, that the transformer (a large one) will excite the resonance of the casework and make some noise.
Feb 16, 2009 | NAD C270 2-Channel Amplifier
Using NAD t743 with Panasonic DMP-BD55
The reciever you have has 5.1 inputs at the backof it.The only way to get Dolby True HD and DTS HD is to run the 7.1 analog out from the bd55 to the nad. You'll have to leave the 2 rear surround open on the bd55 leaving the remaining 6 connected to the nad. The digital coax and the optical will not transmit the hd data, only the analog out will. Run a hdmi right to your HD tv for picture bypassing your amp. this will workfine and you'll have the audio you want. You,ll have to change the input settings for dvd in your amp to 5.1 to recieve the audio.
Dec 14, 2008 | NAD T743 Receiver
My NAD T763 turns on but no sound comes out of any speakers
I had the same problem and AH reset did not work. IS there anything else i can do?
Dec 02, 2008 | NAD T763 Receiver
Nad c372 prob
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Sep 05, 2008 | NAD C372 Amplifier
Panasonic pt-51hx41e tv screen codes
I found this on the net let me know if this works for you Once you are in service moce on a Panasonic you must continue through all steps to the end to exit. It starts with the B parameters, then C, S, and M, then you can exit by pressing power and action ON THR RECIEVER for 2 seconds. The TV will turn off and come back on on ch3 with sound. BTW, you advance thru the menus by pressing power on the remote.
Oct 05, 2007 | Panasonic PT-51HX41 51" Rear Projection...
NAD T762 - no sound
Try reseating the prologic/output board. Second one from the right (from the front of the reciever), that fixed my no sound problems on many channels. You will have to take out a few screws to remove and reseat it, and while you are at it clean the connections.
Sep 08, 2007 | NAD T762 Receiver
105 people viewed this question
