Question about Acer AL2216W LCD Monitor
Acer al2216w problem
Hi. i have a problem with my acer al2216w.when i connect my pc to it with an vga>hdmi cable it tells my something like input not suported.plz help
    Problem Solver:
  • 11 Answers
Hdmi is digital and vga analog you better connect it with just vga or dvi and hdmi to dvi is also possible because they are both digital
Posted on May 21, 2010
  • 186 Answers
Wronge connection check it
Posted on May 01, 2010
How to connect asus p1801-t to tv ?
This PC is equipped with a NVIDIA GeForce GT 630 2GB DDR3 VGA/DVI/HDMI PCI-Express Video Card. This means if your TV has an HDMI input connector you can directly connect the pc to the Tv with an HDMI cable and select the corresponding graphics monitor connection in the Display properties. Alternatively if your tv has only got a VGA input that can also be used from the PC and you can connect the speaker or headphone audio output to the audio input of the TV with a suitable 3.5 headphone to RCA adapter.
Aug 24, 2014 | Computers & Internet
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Can not hook up to my Toshiba TV what cord do i need in order to make it work
Since this model of All-In-One Computer already has a built-in Digital/Analogue Television Function, as part of its standard specification, I will assume that your reason for wanting to interconnect these two devices is that you want to export computer, internet or other IT-based multimedia images to the TV for an enhanced viewing experience due to the TV's larger screen size.
The All-in-one computer has a High Definition Multimedia Interface (HDMI) Port.
If the TV also has an HDMI port, what would be required is the best quality HDMI Cable that the User can afford.
All electrical/electronic interconnections between cables and ports suffer some degree of degradation or dissipation of the signal traveling along the cable. The most efficient metal for electronic connections is gold due to its comparatively high level of electrical conductivity compared to that of other metals used for electronic interconnections.
The best cable choice would therefore be a gold-plated HDMI Cable (see below).
If the TV has no HDMI port, an HDMI to Video Graphics Array VGA Cable Adapter or ([Victor] Radio Corporation of America - the inventors) RCA/PhonoVideo Cable Adapter between the HDMI Cable leading from the computer and the corresponding VGA or RCA/PhonoVideo port on the TV should resolve the connectivity mismatch (see images below).
Once connected, the TV Remote Control should be used to change the Signal Source Input from its automatic standard (Default) setting to PC Input:
Menu -> Source -> PC -> OK.
Nov 25, 2011 | Acer AZ5700-U4002 23-Inch All-In-One...
What do i need to connect my acer 5732z laptop to my sony bravia flar screen LCD tv so as to use the TV display as a large monitor. The TV has a HDMI output from a PC. There is no HDMI o/p on the PC
If there isn't no HDMI output from the PC, then you cannot use the HDMI option on your TV, however if your TV does have a VGA input option, the input adapter that look like that on your laptop, then all you need to do is buy a VGA cable from wal-mart or bestbuy. Walmart is cheaper though, however there is also option of buying a VGA- to HDMI cable on ebay if you want to go that option and wait couple of days for your item to arrive.
Feb 06, 2011 | Acer Computers & Internet
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
How to use my HDTV for a monitor for my computer
What video output connection type do you have on your PC.....DVI, VGA, S-VIDEO, HDMI?
What video inputs connection types do you have on your HDTV.....DVI, VGA, S-VIDEO, HDMI?
The cable you need will be whatever connection you have....ie: DVI----->HDMI or VGA----->VGA or DVI to DVI.
You will also need an audio cable, 2 Phono RCA Red/White (Left and right) -------------> audio output jack plug or Optical in------->Optical out
Thanks
Sep 05, 2009 | E-Machines eMachines Desktop PC
No image on hdtv
First off, is the tv set to use the hdmi input? if not, change tv to hdmi input and try again. If still no good, you likely need to tell the laptop to use the hdmi connector. Try this:
  1. connect hdmi from laptop to tv and select hdmi input on tv.
  1. while holding the blue fn key (bottom left side of kbd) press and release the F5 key. This will toggle the laptop between the laptop lcd display, external connectors (vga/hdmi), or both simultaneously. Let me know if this works or not.....
Aug 08, 2009 | Acer Aspire 6930-6455 Notebook PC
Can you connect a acer aspire one to the tv via hdmi
You cannot connect your acer aspire one via HDMI as its not having HDMI port. But you can connect via VGA cable and most of the TV supporting HDMI will also definitely support VGA input.
Jan 10, 2009 | Nokia IP 350 Firewall
Acer AL2216W LCD Monitor Logo
463 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
