Question about Singer 3116 Simple
When i start to sew the needle get stuck and breaks, what can i do stop this?
    Genius:
  • 1,116 Answers
Refer to the maintenance section of the manual for your machine. If you do not have a manual, check at the Singer Company website for a download.
Raise the needle to it's highest position and remove the bobbin case. Cleaning away any lint or thread that may have accumulated in this area.
If the machine requires oiling (only if this is indicated as part of the maintenance), use sewing machine oil only.
Replace the bobbin case - making sure the needle is at it's highest position for proper positioning of the shuttle.
Refer to the manual for threading the machine - make sure the foot is always up when doing this.
Check the bobbin to be sure the thread is feeding in the correct direction from the bobbin spool and through the guides on the bobbin case.
Posted on May 01, 2010
Thread keeps breaking on my E&R machine. Making bean bag, and started off o.k. but nothing I do now stops thread breaking! HELP
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 07, 2013 | Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
The needle thread breaks
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Dec 20, 2012 | Sewing Machines
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Sep 16, 2012 | Singer 7436 - INGENUITY
How to stop thread from breaking in an older morse sewing machine
Sep 14, 2012 | Sewing Machines
Thread breaking
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
Aug 13, 2012 | Janome Sewing Machines
Singer quantum futura ce200 - thread breaks
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
Is there any other thing I can do to stop the thread from the upper looper from breaking after about 30cms of sewing. there is no sign of it being about to break. I have changed thread, needles and...
it could be due to one or more of the following
  • Threading is not correct.
check that bobin is not snagging thread,
remove bobin and remove any dust and fluff from bobin area
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Correctly thread machine.
  • Replace needle with correct size.
  • Properly insert needle.
  • Start machine at a medium speed.
  • Check threading order.
I hope this was helpful
Jan 05, 2011 | Husqvarna Huskylock Computerized 910
Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Jun 08, 2008 | Brother 1034D Mechanical Sewing Machine
Get a solution please
I am a sewer so I can explain to you what to do you lift it up your needle might break. If so you twist the thing and take it out. Then peplace it with the other needle that fixes it.
Mar 02, 2008 | Janome Harmony 2041
Singer 3116 Simple Logo
140 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
