Question about Fluke Networks Fluke T5 1000: Fluke Electrical Tester, 1000V
It only displays 680 volts when testing dc and 64 v when testing ac and will not register resistance. Is there anything I can do?
  • 10,319 Answers
It will be repaired at a Fluke repair facility. They are not easily repaired by do it your selfers
Posted on May 01, 2010
Hi I have a 1978 Suzuki GS 550 how do I check the charging system?
Hi, Israel before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter lead.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Your Suzuki GS750 Charging System kendoll net
Thread 81 GS550 charging problems
Suzuki GS550 Service Manual
OEM parts for Suzuki
Suzuki GS500 Owner Manual
Apr 13, 2017 | 1979 Suzuki Gs 550 L
Tip
How to use a voltage or multi meter.
You can buy a reliable, two probe voltage meter at most building supply stores for around $30. They typically have two testing probes and a dial to select the function. The four major functions are AC voltage, (a V with a wiggly line), DC voltage (a V with a straight line), resistance or continuity (the symbol omega), and amps(A). To use the meter you decide what value you are testing for and estimate what range the result would be in. For example, testing a receptacle, you would use AC Volts on a 200 range, expecting a 120 volt reading. For continuity or resistance, select a mid range to start with. Hold one probe to each side of the circuit or item to be tested. If the reading is infinite then there is no internal connection between the parts tested. If the reading is zero then there is a connection or a short between the parts being tested. For example, if you put the probes on the terminal screws of a switch, one position would give you a zero reading, and flip the switch and you would get an infinite reading. For a light bulb an infinite reading means it is burned out, a zero or close to it reading means the lamp is good.
You would use the DC Voltage function to check circuits in your car, or to check batteries. The car is 12volts DC and a battery is 1.5 volts DC.
on May 10, 2010 | Hammering
1977. How do I use this machine to test my module?
this is a volt/ohmmeter.
an "Ohm" is the measurement of resistance in a circuit. ...ie, a wire going from point A to point B is what you would call a short circuit.Sometimes wires are supposed to be connected directly to another point, therefor that is a short circuit on purpose. If the same wire was cut between point A and point B, then that is what is referred to as an "OPEN" circuit, and the ohms would be very high like infinite. OHMS in a short circuit would be measured as 0 (zero).
Voltage in a house is called ALTERNATING current, or AC. Voltage in a car is called DIRECT current, or DC.
Always make sure you select AC on the meter in the range of higher than what you're measuring. ...ie house uses AV120volts, therefor the meter should be set to 200, or anything higher than 120.
Set the meter to 20volts DC when checking a car, which uses 12v DC.
If you want to see if your car's alternator is charging the battery, select DC voltage (20 Volt range) on meter and place positive (red) probe on POS (+) on battery, and place negative (black) probe on NEG (-) on battery. The meter should indicate 12Volts DC if the car is off. The meter should indicate somewhere around 13 or 14 volts DC if the car is running and the charging system is functioning properly.
happy troubleshooting!
Dec 23, 2015 | Dodge Cars & Trucks
1994 Honda VF 750 C Magna no battery power
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
Stator Ground Check:
If there is continuity your stator is shorted to ground and must be replaced.
5. Regulator Test:
Identifying Wires:
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
94 magna has no power to anything
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Apr 06, 2014 | 1994 Honda VF 750 C Magna
1985 gl1200 overcharging at idle will climb to16 volts, new battery
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Regulator Test:
Identifying Wires:
85 ltd Goldwing is charging at 16 volts
HOW TO CHECK YOUR CHARGING SYSTEM and CHANGING the STATOR and REGULATOR...
Honda GL1200D Shop Manual
Honda GL1200 1986 Owner Manual
Apr 14, 2013 | 1985 Honda GL 1200 Ltd. Ed. - SE-i Gold...
How to use greenlee testervolt dvc-6
http://www.westwaysupply.com/fw487627.html
Here is the Instruction Manual in PDF file form,
http://www.mygreenlee.com/GreenleeDotCom/im/im1397.pdf
Shows which is the Fixed probe and which is the movable probe, which indicator LED's are for AC or DC, and Positive and Negative, and so on.
Voltage measurement (DC from 12 volt to 600. AC from 120 volts)
Continuity check (OHM's)
Resistance measurement (OHM's)
Identifying energized conductor
Ground Fault Circuit Interrupter test. (GFCI)
12 pages in English
Regards,
joecoolvette
Sep 17, 2012 | Televison & Video
1992 yamaha vmax not charging
Hi, Anonymous before testing any electrical component in the Charging System Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
http://www.starvmax.com/kunena/12-general-vmax-discussion/132078-vmax-charging-problem
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Yamaha Vmax VMX17C 2009 Service Manual
OEM parts for Yamaha
Yamaha MAX VMX17YC Owner Manual
May 11, 2012 | Yamaha V-Max Motorcycles
XT 600 charging system
5. AC Output Check:
Generic Specs:
Generic Specs:
Identifying Wires:
XT600 not charging battery Horizons Unlimited The HUBB
http://www.sloneservices.com/SilverBack/Other-Stuff/VS-1100-chagre-syst.pdf
Yamaha XT 600 AC Service Manual
Yamaha XT500E Owner Manual
Apr 05, 2012 | Yamaha XT 600 E Motorcycles
Dead battery on a 2000 Yamaha road star
Hi, Masseybrett before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
Stator ground Check:
5. Regulator Test:
Identifying Wires:
Dead battery
Re Parasitic Battery Drain Road Star Forum Yamaha Road Star
Yamaha XV16AL Service Manual
YAMAHA XV1600A Owner Manual
Sep 24, 2011 | 2002 Yamaha Road Star
Honda 2004 Sabre will not charge the battery
Hi, Rhall20448 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Stator Ground Check:
6. Regulator Test:
Identifying Wires:
Why won my battery hold charge
Honda Shadow VT1100C Charging System Repair
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jul 27, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
Fluke Networks Fluke T5 1000: Fluke Electrical Tester, 1000V Logo
210 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
