Question about Garmin StreetPilot c340 GPS Receiver
Garmin GPS touchscreen is damaged - what can I do?
My Garmin GPS touchscreen in damaged. Can I replace the screen?
I have a Garmin StreetPilot c340
Thanks for the help
  • 5 more comments
  • Anonymous Apr 14, 2008
    my garmin c330 gps's screen is demaged i want to get it replaced.hoe can i get it repaired or replaced and how much time they'll take to repair or replace and how much it will cost me.
    would garmin repair or replace it if yes so in how much time and what it will cost me.
  • Dagnis Kravalis May 20, 2008
    Thanks for the help
  • Anonymous Jun 09, 2008
    I have a garmin ST pilot 7200 and I need to repair tuch screen help please
  • Anonymous Jul 15, 2008
    Is there a place to buy replacement screens for the Garmin Street Pilot 7200
  • blue1977leaf Sep 13, 2008
    I have a Magellan 3225 unit with a crack spider-webbing out to the sides of the unit, there is complete inactivity at this point.... Can it be repaired???
  • Anonymous Feb 07, 2009
    Screen is cracked. Won't let me add addresses on anything on right side of touch screen.
  • Ron Chinnery May 11, 2010
    By touchsscreen, do you mean the LCD, or simply the touch overlay?
    If you mean the overlay, is it completely inactive, or partially functional?
Overlay is dented.
Posted on Sep 13, 2008
SOURCE:
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
Garmin streetpilot c530
Requesting you to please elaborate on the question and explain the issue that you are experiencing with the Garmin StreetPilot c340 GPS Receiver.
Nov 01, 2010 | Garmin StreetPilot c340 GPS Receiver
Can the touch screen on my garmin c340 gps be replaced?
Yes, it could be easily replaced. If you want to purchase only touch screen, buy it from :-
http://cgi.ebay.com/GARMIN-C340-C-340-Street-Pilot-Touch-Screen-Digitizer-U-/270622808154?pt=PDA_Accessories&hash=item3f0260585a
If you wanted to replace LCD screen as well, buy it from :-
http://cgi.ebay.com/LCD-Screen-Touch-Digitizer-Garmin-C340-U-/120457660971?pt=PDA_Accessories&hash=item1c0bd60a2b
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 27, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin c340 has locked up while in middle of road trip. had this unit 5 yrs, no probs Til now. stopped at roadside park, came back it said recalulating, then screen showed calc at 100%, but unit is...
remove the battery directly from its back for 1 hour and then reinsert it and then try.its got hanged in the standby mode and needs to be reset.this will help. keep updated.
May 04, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin streetpilot c340's screen turns on and then goes black. I have it plugged into my car but it still won't stay on.
I found the solution on another blog. He said to try resetting the reset button . It worked. The button is located under the front screen. Remove screen frame by fingernail under the Garmin name. I'm thrilled. navinscs
Jan 25, 2009 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not come on even when plugged in
I had this problem before, i called garmin and they told me that the charger cradle was not design properly so it sometimes doesnt charge...anyways...carefully remove the grey cover around touchscreen and there is a master reset which will set it back to factory...it worked for me...good luck!
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
StreetPilot C330 Need a Screen
If you are technically incline, purchase a damaged unit off ebay and swap out the parts. Take note that taking the Garmin apart is not difficult, just keep note of how the antenna comes out. That is the only hook I know that will hang up most people.06dd1c8.jpg
Jul 21, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
2,978 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
