Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
Just bought this Hoover Fusion vaccum used, cleaned it up, checked belt and filter, turned it on and is extremely loud, almost like a scream. Any idea what could be causing this and how to fix?
  • 294 Answers
Loud noises from this model are caused by dirt build up on the suction fan mounted directly to the motor. Under the dirt cup there is a filter screen that should have a foam filter insert, when not used or cleaned properly allows dirt to get into the motor. Cleaning is the best option. Although if you are inclined, you can take it apart or take it to your local deaLer.
Posted on May 02, 2010
My dyson dc24 brush bar will not turn and there is a very loud screaming noise coming from the Hoover
Something has jammed the brush roller and the screaming sound is the motor shaft trying to move the stuck drive belt. The vacuum will have to be disassembled to find and remove the jamming material.
Oct 23, 2016 | Dyson Vacuums
Why is my hoover spin brush making a loud noise when i turn it on
Check for clogs starting with the air passageway at the bottom.
A piece of TV cable or similar works well as you have to snake
it in. Check all hoses, Are the filters clean? If you can, remove
the brush bar and belt then turn vacuum on. If the vacuum is
no longer making a loud noise the side bearings on the brush
bar are the problem...replace the bar or spray a bit of WD40-
if you do that wipe well before you vacuum. Finally....if the
vacuum was still loud with the brush bar off...you have a motor
problem and that could be expensive.
Regards.
Dennis
Aug 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My Windtunn begless hoover vaccum cleaner which i bought in dec gets very hot and smells like burning and belt gets hot and then it splits in two pieces,i changed 3 belts already .i bought it from...
check to make sure that the brush wheel turns freely ( without belt on ) -- if it does not turn freely then there could be hair or carpet strands twisted up on the ends of the wheel,, inspect and clean. also make sure that the wheel cartridge is sitting nicely in its mounting area,, ( again - make sure the wheel turns freely ). now if it is moving freely - then make sure the height adjustment on the vacume is set to the proper height for your carpet thickness,, it kinda sounds like the brush wheel is not turning because it has to much pressure on the floor.
so -- make sure wheel spins freely,replace the belt and adjust the height and then check the unit for proper operation.
c...
Feb 03, 2011 | Hoover U5750-900 WindTunnel Bagless...
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Extremely loud and smells like rubber burning
the loud will be the line is clog up and need to unclog the line, rubber burning will be the belt, which is worn or the brush is jam not allowing the brush to spin freely. check and clean the line and inspect th belt which run from the motor to the brush
Nov 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Loud rattling noise.
Hi there SmartAlec from NelsonVacuums.com.au here. Often when an upright is making a rattling noise it can be something caught in the roller and every time the brush turns it knocks against the body and since it turns really fast it can sound quite bad. Take the roller out and clean inside that area and see if that helps. Hope it does. Happy Vacuuming :)
Aug 03, 2009 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Vacuum gets louder
take the belt and roller loose then turn it on .if the noise is gone then the problem is in the base.disconnect the hose and try that.remove all the filters.check the brush roller and see if it turns freely remove all strings and carpetstrands from the ends of the roller.look at the belt and see if there are any burn marks on it.if its a eureka they tend to get loud
Apr 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Extremely loud
Mine started making a lot of noise and my husband noticed the brushroll was slightly bent. I have no idea how this happened, but I noticed several people online were having the same problem. I ordered a new brushroll and popped it in and solved the problem. The noise before I did this was horrible! It is now back to normal.
May 23, 2008 | Hoover U5507900 Elite Rewind Bagless...
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover fusion plus cyclonic upright vacuum
While I'm having a different problem, the problem you guys are experiencing can easily be fixed by cleaning the two internal filters. My vacuum did the same thing, just stopped running mid-stream. Remove the main filter cup. Look inside the cavity of the vacuum and you'll see a grey bar at the bottom of the cavity, pull this up and you'll find the first of two washable filters. Just rinse it under warm water squeezing as you rinse until the water runs clear. The roll the filter in a few paper towels or towel and unroll, reroll until completely dry - should only take a few minutes. Then, look in the same cavity except up top there is another filter which seems to be hidden. The back wall of the inside cavity will guide you to these filters as well. You will be amazed by the difference cleaning these will make in the suction power of your vacuum. Also, if you remove the belt cover and clean out the hose in this area it will improve suction as well. Hope this helps. Now, if I could just get the darn belt back on mine. First belt smoked and popped. Bought replacement belt, smoked and popped within seconds... HELP!!!
Dec 16, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
