Question about Lexmark Wheelwriter 3500 Typewriter
IBM WheelWriter 3500
The typewriter does nothing but display a little box with a slash thru it and the numbers 215. It does not make if you power it off or unplug it, it continues to display that error code (I'm assuming) on the screen.
  • albetohe Mar 26, 2008
    I tried this and the 215 code still remains unchanged on the display screen; could that also mean the keyboard is bad? Or can I simply throw out the old thing and tell the woman in that dept. to get with the times ;-)
    In any case, thanks for your assistance.
  • Lexmark Master
  • 3,594 Answers
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Posted on Mar 25, 2008
IBM Wheelwriter 30 Series II is showing an error code of 215 with a box with a slash through it and am unable to type on it
215 is a Print Wheel error. Remove the print wheel, look for debris in the P/W area, if you have a compressed air source blow the P/W area out. If these don't work the P/W sensor is probably bad.
DickyO
Sep 07, 2011 | IBM Wheelwriter 30 Typewriter
I have an IMB Wheelwriter 30 Series II. When I turned on the machine this morning it made a couple of ringing sounds and then on the display it reads a square with the number 215. Nothing else works on...
215 is a printwheel error. Remove the P/W, look for dirt or debris in that area, if you have a compressed air source blow out the P/W area. If these fail the P/W led sensor is probably bad.
and you most likely need a tech.
DiclyO
Sep 06, 2011 | IBM Wheelwriter 30 Typewriter
What does a box with a slash and 215 mean? we can't find our manual and I need to type diplomas for graduation today
215 means that the T/W isn't seeing the printwheel. Remove the P/W. look for debris in that area, blow some canned air into that opening, be sure the P/W is fully installed. If these don't help the LED is probably Bad.
DickyO
Jul 03, 2010 | IBM Wheelwriter 30 Typewriter
My IBM Wheelwriter 30 Series II has a message of a box and an X in it and then the numbers 215 can someone tell me how can fix this?
Check to be sure the printwheel to be sure it is properly installed, check for debris in the P/W area, If these are OK then the sensor is probably bad.
DickyO
May 28, 2010 | IBM Wheelwriter 30 Typewriter
In the display box there is a box w/ a slash through it and the number 215 following it. everything seems to be locked up - what do I do?
The book says bad keyboard. Try unplugging and repluggin the 2 keyboard ribbon connectors. If that fails contact Geo. Beyers Co. @1-800-392-8085 for a rebuilt keyboard.
DickyO
Aug 17, 2009 | IBM Wheelwriter 30 Typewriter
IBM WHEELWRITER 30 SERIES II
I believe a 215 code is a bad printwheel sensor. You need a tech.
DickyO
Mar 05, 2009 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 25 message: a box and diagonal line thru it and the number 215.
Code 215 is a printwheel error. Remove the P/W and look for debris in that area, if you have some compressed air source blow this area out, if this dosen't do it the P/W sensor or the LED are probably going bad.
DickyO
Nov 01, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 3500
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
Oct 09, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Series II Typewriter 6787
The book says turn the T/W off wait 30 seconds and restart, if condition returns call for service. However you might try removing the batteries and unplugging the machine waiting a few minutes and restarting. CAUTION ALL THE MEMORY WILL BE LOST!
DicktO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
Code 215
I don't know where you are but if tou can get it to us we will give you a free estimate. We are in Cleveland Ohio
bizmach@earthlink.net
DickyO
Apr 01, 2008 | Lexmark Wheelwriter 3500 Typewriter
Lexmark Wheelwriter 3500 Typewriter Logo
168 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
