Question about IBM ThinkPad T30 2366 Notebook
CPU Speed too slow
I have problem with cpu speed. i have a pentim 4(M) 2 Ghz but now it works with 770 mhz. (if u click with the right click on My Computer: Pentium 4(M) CPU 2.00GHz
770 MHz, 512 MB of RAM
and i dont have any idea why that. i cant work with anything with 770 mhz, too slow.
what should i do to have back 2 Ghz of speed?
Thank u, Sonny
  • Sonny_01 Mar 25, 2008
    i have to u use all 3 antivirus (avast,quick heal ,symantec) or just 1 of them?
    Genius:
  • 1,913 Answers
Hi
your sys is really so good.
check in task manager identify some unknown proess .
they are virus.
clean all temp files.
disk cleanup run.
scan your sys with avast,quick heal ,symantec one bye obe with update definition in safe mode.
then u get some malware and viruses.
then delete it.
after that run chkdsk utiliity.
then defragmen all drive
now your sys really speed up.
best of luck my friend.
Posted on Mar 25, 2008
How to upgrade the cpu of my acer travelmate?
Try setting the bios to accomodate the required speed.
Aug 06, 2014 | Acer TravelMate Computers & Internet
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
I have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting Intel.com (see the Below ) to research and figure out which processor you want. http://www.intel.com/products/processor/index.htm Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit Newegg.com (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. http://www.newegg.com/Store/Category.aspx?Category=34&name=CPUs-Processors You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Jan 21, 2013 | eMachines EL1333G03w (884483010820) PC...
Want to upgraded Pentium 4 2.8 GHz to Pentium 4 3.2E GHz
why not go with a faster MB and CPU combo?
First to awnser your question yes the Pentuim 3.2 will fit the MB as long as yours is a 800 Mhz Bus speed. And the Board can be configured for the proper clock speed. I would also buy a new CPU fan and heatsink greese b4 you install this CPU. Thee are so many cheap CPU MB Combos out there its almost cheaper to just replace both and get a much faster system.
Jun 03, 2010 | ATI RADEON X1650 Graphic Card
I need the breakdown on the gmax 5 allison 5 speed
Under Windows XP, click Start
Click with the SECOND (usually the RIGHT) mouse-button on "My Computer".
Click Properties.
The first screen will run a short "speed-test" to determine your "actual" CPU-speed, and to display the "rated" CPU-speed, e.g., 3000 MHz running at 2.99 Ghz.
Apr 23, 2010 | Gateway GMAX 2100 Computer Speakers
Cpu clock in my bios read only from 1200 to 1600 mhz.
Please read carefully the chapter 2 (page 33 and 47) of User's Manualfound at:
http://support.asus.com/download/download_item.aspx?model=P4S8X-X&type=Manual&SLanguage=en-us
I suggest you select "Auto" on "CPU Speed" setting in the BIOS "Advanced" Menu or adjust 18x in "CPU Frecuency Multiple" if posible for reach optimal setting.
May 04, 2009 | ASUS P4S8X-X Motherboard
2 ghz processor running at 220 mhz
Have you tried right clicking on the desktop (opening Display Properties), clicking on Screen Saver tab, Clicking the Power button, and setting the power schemes to Home/Office Desk? If its set on laptop it will reduce the processor speed when running on battery. I have noticed that even with it plugged in that some times it will run at half processor speed. Try that out.
Have a great day,
Armymason
Mar 02, 2009 | Dell Inspiron 9300 PC Notebook
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Toshiba a30-931 what is largest posible cpu
Franky_J knows nothing you could go for a P4 2.8 cpu which would work much better than the Celeron in fack any P4 over 2.0 would out perform the celeron if you want speed get rid of the Celeron and get a P4 it should take up to an 3.2 P4 chip.
Franky if you dont understand cpu's then you shouldn't really be answering this question in the cpu world a 2.8 ghz cpu is not always a 2.8ghz cpu for instance this one has half the cash of a P4 cpu meaning it can only do half the work at the same time so in P4 terms this is only a 1.8 P4 equivilent so a 2.8 P4 will be a big improvement.
Nov 25, 2008 | Toshiba Pentium 4, 2.88 GHz (P000382340)...
IBM ThinkPad T30 2366 Notebook Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
