Question about Metabo W14 125 Ergo Angle Grinder 5"
May i fit bigger disc on my angle grinder,its speeed is 11000 rnd.p minutes,recomended 115 mm disc.i want to fit other big disc.may i do it?will it cause any problems?
  • 34 Answers
There are 3 problems you might face: 1. mechanical - disc shield (or protector) is too small for bigger disc. You can remove the shield (I do not recommend!!!) or buy bigger one (as I've did). 2. RPMs - on each disc you can find maximal speed of ourter part of the disc. It depends on disc diameter and RPMs. In case yo go from 115 to 125 at 11 000 RPM, it should be still OK. But I would not go further. Check how RPMs drops with increasing disc diameter. 3. motor overload. To handle bigger discs motor should produce higher torque. But if you are not pressing on the grinder and you frequently check temperature of grinder, it should work. I have Metabo WE14-125 - 1400W motor 125 mm disc: 1. I've bought new shield from WE14-150 - it fits perfectly 2. My grinder has adjustable RPMs, when I'm using 150 mm disc I'm not going over level 3 (out of 6) to keep RPM in safe range for the disc. 3. Metabo makes also WE14-150 which is almost same as mine, but produces more torque (3,5Nm vs 3,3Nm). But the dofference is very small so I'm not worried. Juraj
Posted on Jun 08, 2010
  • durikniz Jun 14, 2010
    Just checked Metabo page. They make also 150mm version of your grinder. W14 150. Technically same spec (1400W, 10000 RPM, 5Nm, 2.8kg) - you can safely do what you planned. Ask your metabo dealer to order 150mm disk shield for you, so you can work safely.
    Juraj
    Problem Solver:
  • 14 Answers
You should NEVER put a larger disk on a grinder then what its rated for. Aside from the immediate issues like having to get another guard and possibly working the tool harder then what it was designed for in the event of an accident, insurance coverages are out the window and if you have a work crew using it the liability issue goes up like a rocket!
Posted on Oct 08, 2014
What tool do I use to take off the break calipers to change brakes
9mm six point socket should be available from any good parts store or hardware.
Jun 12, 2015 | 2007 Ford Expedition Eddie Bauer EL
How do I change disc
Mine came with a special wrench that fits into the "nut" that holds the wheel on. Make sure the grinder is unplugged. Mine also has a button I push in that locks the shaft.I lock the shaft put the special wrench into the nut and spin it off.
Sep 13, 2014 | Hitachi G23sc2
Misplaced my angle grinder's inner disc flange
If you use a nut, the arbor nut will not hold your grinding/cutting wheel properly and you'll use up threade the arbor nut needs to tighten. What you need is the clamping flange, Bosch part number 3603340501. If you have a tool repair center near you they may have one or can order you one. If not, you can get one on sites like www.ereplacementparts.com.
Dec 06, 2012 | Bosch 1800 4 1/2" Angle Grinder Cutoff
To sharpen tools
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
Jul 29, 2010 | Delta ShopMaster 8in Grinder with Light...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
I borrowed a B&D 7750 3 to cut off the legs on a wire shelf system. I would like to replace the grinding disc but it appears to need a special tool to remove the disc. Is that correct? The owner says...
Yes you need an angle grinder spanner/wrench. It is like a tool with two pins that fit in the holes of the grinder disc securing nut. You can see a picture of one here: http://images.toolspot.co.uk/Angle%20Grinder%20Accessories/Angle%20Grinder%20Spanner%20For%20412in.jpg
They do come in different sizes, but you can also buy adjustable ones. Your best bet is to take the grinder to the local hardware store, big box outlet or anywhere power tools are sold and they should have a grinder spanner to suit your grinder.
Jul 03, 2009 | Black & Decker 7750 4 1/2'' Small Angle...
Angle grinder issue
Do you have the securing nut on the correct way? Basically the inner surface of the nut needs to be flat against the blade for it to work correctly and hold the cutting disc in place Usually the nuts are reversible to fit either flat discs or rounded disc heads. It's either that or you do not have the right size bore on the diamond disc for your grinder.
Jun 15, 2009 | Black & Decker 4 1/2" Small Angle Grinder
Disc flies off when grinder stops
yes the above is correct with the question "are the threads the right size." but it can also be because u are not slowing the grinder down before stopping it. if the grinder stopps to soon the disk will stay moving. so the disk will fly off. i had the same problem with a pnuematic grinder. sometimes it is the operaters fault not the tools.
" an object in motion aloways stays stays in motion till an outside force dissrupts it."
Jan 10, 2009 | Metabo W6-115 606111420 4 1/2" Angle...
Metabo W14 125 Ergo Angle Grinder 5" Logo
359 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
