Question about Reliance & 30 Gal Mobile Home Water Heater
Water heater burner assembly.
I'm moving from town and out to the woods.I have a mobile home trailer with a natural gas burner.I'm going to need an LP gas burner assembly.what is the cost of the assembly ,and is it easy to install?
  • Reliance Master
  • 6,674 Answers
If you check with manufacturer, you may find out that changing the orifice in the gas valve, is all that is necessary. If you can't get information, get back to me with make, model and serial number off the heater and we'll see what we can find out for you. You might find that a local gas appliance dealer, or technician can do that for you at a reasonable price.
Posted on May 02, 2010
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
How do I convert my rheem water heater from lp to natural gas model#21vp40-1p
Call Rheem
Generally the company does not support changing type of gas since propane burns much hotter and has more pressure than natural gas.
You need different gas control valve, and need cast iron burner and orifice than matches that specific gas control valve.
http://waterheatertimer.org/images/IMG_1826-LP-burner-450.jpg
http://waterheatertimer.org/Water-heater-manufacturers.html
Gene
Sep 14, 2014 | Water Heaters
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Luke warm water
is the water temperature dial turned up? or even functioning?
Jul 28, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Rheem 300170 HWS service manual
1) Rheem does not post service manuals.
Call Rheem and ask why, since the other big manufacturers, AO Smith and Bradford White do post service manuals.
2) You need new propane gas control valve, and matching combustion parts to fit existing tank.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
3) Rheem does not recommend changing gas type, especially from natural gas to LPG.
LPG is higher pressure, and burns much hotter and requires cast iron burner, unlike the lighter-weight metal used for Natural gas burner.
The manifold tube and thermocouple must match the gas control valve, and gas-type and have correct thread for propane.
The combustion chamber and heat transfer surface can also be heavier metal for propane heaters.
Feb 08, 2013 | Water Heaters
Need gas control unit& burner for water heater 40 gallon
Reliance is AO Smith.
Each gas control has identifying information on side of gas control valve. Make sure you order for NG natural gas or LP propane gas, since these are two different gas control valves.
Google search the gas control number and results will show.
Copy following links for more help:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Sep 03, 2012 | Reliance Water Heaters
Recently i got a hotwater heater installed in my home, i was told it was for natural gas and i believed the "experienced salesman". turns out they rigged a propane hotwater heater into my homes...
Those dirty crooks, Only kidding. They did the same thing to me a while back, except it was a natural gas heater with lp tank out in the yard, bought it from the gas co who services the tank, found out they ordered a dozen heaters, all of them natural gas. I said to the guy, do these need to be switched over or jetted or something? He says why, I said because it says natural gas only. It worked fine, just smudged black smoke out. He brought out another heater and swapped it out, seems you can't change the burner? Don't make sense. Anyway, I would take it back to the place you got it and say get up the coins, It cost $400 to get the plumber back to hook this thing up!! And we have no hot water. And my shotgun has a hair trigger. I would say it is dangerous enough to get his attention on the matter without going to court. Hope this helps.
Dec 21, 2010 | Water Heaters
I just had a noritz tankless hot water heater converted from LP gas to natural gas, and had the hot water heater moved outside my garage. Before the gas change over and the move, I could turn on my garage...
One thing that comes to mind right off is did they use proper size orifices when they converted? L.P. uses a much smaller size then natural gas because it runs at a much higher pressure. Just a thought but I had a water heater from the factory for a mobile home that had the nat. gas sticker on gas valve and I hooked it up in town to nat. gas supply. Unfortunately it had L.P. orifices and I was in a hurry to get to another job ,lit it turned burner on and left. Two hours later my customer called to say they didn't have enough hot water. Didn't take long to discover what the problem was and correct it. Thank god for good customers. Hope this helps you. Thanks
Nov 24, 2010 | Bosch Indoor Gas Tankless Water Heater...
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: hi i have a rheem tankless water heater, with flas...
Sounds like you may have the wrong type gas going to this? Is this an LP gas or natural gas unit? will say on label. Natural gas units run only on natural gas ditto for LP. Could be issue with manifold pressure settings. Could be obstruction in exchanger or vent. Have a authorized technician check over
May 17, 2010 | Rheem Tankless Hot Water Heater...
WHAT SIZE HOLE IN JET ON HOT WATER HEATER TO CHANGE FROM NATURAL GAS TO LP GAS
That doesnt work with these units they are manufactured gas specific. The manifold plate would need to be changed as well as notification to Noritz to have a new serial # issued. PC board reprogram required, etc. Buy a natural gas or LP model.
Apr 27, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Reliance & 30 Gal Mobile Home Water Heater  Logo
137 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
