Question about ViewSonic VA1930WM LCD Monitor
Monitor won't recognize laptop
I have had a ViewSonic monitor for a little while that I hook my laptop (IBM T60) up to. The connection between the monitor and laptop was fine. Now the monitor says "No signal" and no matter what I try, I can not view my screen via my monitor. Any suggestions are welcome!
  • 186 Answers
Vga cable could by defective
Posted on May 01, 2010
Had a pink screen on my T60, has now blacked out
Try connecting an external monitor and check if it has the same issue. If it does, then replace the LCD.
Feb 27, 2013 | IBM Lenovo ThinkPad T60
Bottom half of laptop screen is colors with white lines vertically. Was able to control by changing position of screen, no lnger able to do that. Thin k Pad Lenovo T60
Try to hook up an external monitor just to check that it is not a problem with the video card of the laptop. Most likely the LCD cable is loose or the LCD inverter needs to be replaced.
Hope this helps.
May 25, 2011 | IBM 92P6569 DVD/CD-RW for ThinkPad R50,...
Few minitues later after i starting my ibm thinkpad t60 laptop i can not see anything on it display monitor. but operating system and all others things are ok. just i can not able to see display on it...
Ok seems like an issue with the LCD screen . Try these steps :
1. do u hear the windows login sound when you turn on the system ?
2. Check for any lblinking lights on the system. Press the caps lock and num lock and check if it responds.
3. Do u have a Desktop at home ? if yes then you can connect the monitor to the system and check for the display.
4. check for any cracks or any kind of damages. Reseat the battery and then power oN . Check for the light on the AC adapter too.
IF the answer is YES for the above then its a issue with the LCD screen.
Apr 02, 2010 | IBM ThinkPad T60 Notebook
Viewsonic monitor lcd to laptop problem
Remove the second monitor entry in Device Manager, and let the machine try to find the driver. I swear, sometimes, computers have minds of their own! ??
Apr 04, 2017 | Computers & Internet
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
How to replace monitor screen on ibn thinkpad t60
I have the same problem with my IBM T60. Screen is very dark, and I have to move it up and down to try to get it to flicker on. Right now, I have another monitor plugged in.
The laptop is about 4 years old and has been used daily.
Aug 26, 2009 | IBM ThinkPad T60 Notebook
IBM T60 can not connect to projector. I have some
Most notebooks have a keystroke that enables the external video port for presentations.
According to the manual for the T60, your Fn +F7 key combination does the following:
"Apply a presentation scheme directly, with no need to start Presentation Director. To disable this function and use the Fn+F7 key combination for switching a display output location, start Presentation Director, and change the settings."
"Switch a display output location
v External monitor (CRT display)
v Computer display and external monitor (LCD + CRT display)
v Computer display (LCD)"
"Notes:
1. This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
2. This function does not work while a DVD movie or a video clip is playing."
"To enable this function, do as follows when you log on to Windows 2000 or Windows XP:
Note: Multiple users can log on to a single operating system by using different user IDs. Each user needs to do the following:
1. Start Windows 2000 or Windows XP, and log on to the system.
2. Start Presentation Director, and change the Fn+F7 settings."
If you would like to see the entire manual, click the link below.
http://technology.shu.edu/faq/page/t60+manual!OpenDocument
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 15, 2009 | IBM ThinkPad T60 Notebook
My Viewsonic LCD monitor showing no siganl and blinking continuously. please provide solution
Make sure cables are properly connected in both ends. If you have it hooked up to a laptop, make sure the external monitor is enabled. Usually you can toggle this with the "Fn" key + one of the F1-F8 keys pressed at the same time.
Also check that no pins in the cable are bent or damaged. Try to connect a different monitor to the PC to see if your monitor is at fault, and/or a different PC to your monitor.
Dec 05, 2007 | ViewSonic VE710b 17" Flat Panel LCD...
ViewSonic VA1930WM LCD Monitor Logo
106 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
