Tip & How-To about Audio Players & Recorders
Right guys before you panic and start to look for the new keys or codes please check that the emu has not been turned off on your box ok so you have a box t press menu then 1570 this opens a new window or a hidden menu in this you will see nagravision and key emu highlighted scroll down to check that the emu has not been turned off accidently if so scroll over press>to turn on then exit exit if it is a digivox repeat the same procedure only key in 1004 and follow the same steps and again the same with the eurovox only again the difference is 1969 and again the same steps just check before you panic it could be an accident and the emu is turned off
