When we ser up our modem/wireless router we couldn't connect the wireless laptop - so we called for assistance. Great Job - all fixed. Recently we logged on with a different laptop only to find that we do not have a secure connection. How do we stop the world connecting through our modem?
  • 20 Answers
I will give you something to try, but with out more info, (type and model of router, and operating system) it might not work.
When you set up your network (home network wizard) you should have seen an option for WEP (wired equivalent privacy) or WPA (wi-fi protected access), your internet service provider should have supplied you with an encryption key to enter there. (if not ask them for one) you will have to re-setup your network to install this number key. WPA is the better of the two but most older network products do not support it so you might be stuck with WEP.
Note: you will also have to set the WEP/WPA encryption number on your laptop (any wireless device) to access your network.
Hope this helps, if not let me know with the other info i requested above!
Posted on Mar 26, 2008
SOURCE:
My HP Probook 4720S has a very wierd problem. The wireless card seems to be working properly, and the drivers are up to date.However it cannot detect the wi-fi in my office.Other laptops are connected so...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
If the other laptops are connecting to the wireless router, then look at the wireless card configuration in these laptops and apply the same settings to your HP Probook wireless card.
Sep 05, 2011 | HEWLETT-PACKARD HP ProBook 4720s 173...
Earlier today I was connected to the internet fine. I stepped away from my computer for a little bit and now it doesn't connect to the internet. The wireless adapter is showing that it is connected to...
Here are some troubleshooting steps that you can do so you can isolate whether the problem is with the router , the modem or your pc.
1. Disable / enable the wireless connectivity in your laptop.2. Restart the laptop. Then check if it is working. If not, go to the next step.
3. Restart your modem and router by unplugging the power cord on the back of the devices. Wait for the devices to load, then check if it is working. If not, proceed to the next step.
4. Try connecting your laptop to the modem directly by using an ethernet cable. If it did work, the problem is with the router. Its best to call the manufacturer of your wireless router if that's the case.
5. If step 5 still didnt work when you already connected your laptop directly to the modem, the problem is with the modem itself. Call your internet service provider and they'll do troubleshooting steps on their end too.
Hope this was helpful! Have a great day.
May 27, 2011 | Netopia 3-D Reach (TER/GUSB-N1)...
I have recently moved from Pittsburgh, PA to Charleston, SC. My linksys Wireless G 2.4 gHz router worked great with the ISP in Pittsburg (Comcast). Now, with Time Warner's Road Runner, I get an error and I...
Connect your main cmoputer directly to the time warner modem. make sure that your computer will be able to go on line when connected directly to the modem. If not then call Time warner.
If your computer is able to go on line when connected to the modem then your modem is working properly. You will need to change the settings of the router.
First reset the router for 30 seconds. On the router you will find a small reset button. Hold it down for 30 seconds. release it. wait for 1 minute. now unplug the power to the router and plug it back in. wait for 30 seconds till the power light on the router will be solid.
Now connect the modem and the computer to the router.
Now you will need to clone the MAC address of your main computer to the router. you will neeed to open the set up page of the router.
once your main computer is online , you can change the wireless settings of the router and connect to the wireless network on the laptop.
Click here for step by step solution
Apr 10, 2010 | Linksys Wireless-G Broadband Router
Adapter issues
Foildemon, If you are still needing assistance with any of your Consolidated Communication services please contact our tech support staff at 1-800-480-0080 opt 1. We are available 24 hours a day 7 days a week for your convenience.
sincerely,
your CCI tech support staff
Dec 17, 2009 | Zhone (6218-I2-200) Router
The internet connection keeps disappearing.
Change the router's IP address to (192.168.10.1) maybe you have an IP conflict between the modem and router.
Mar 15, 2009 | D-Link DSL 300G+ (DSL-300G+) Modem
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
My wireless connection keeps going on and off
you have to connect your computer first directly to the modem to test if you'll get the same problem hook to it. if same problem occurs you have to call your isp or whoever gave you the modem to have it reset or reflashed.
May 22, 2008 | Linksys Wireless-G WRT54G Router
Open Questions:
Computers & Internet Logo
70 people viewed this question
Ekse
Alun Cox
