Question about D-Link AirPlus DI-524 Wireless Router
No connection for a visiting laptop
I have a pc and a laptop and use the laptop with a D-Link DI-524. Everything is great but my sister is visiting and cannot get a connection for her laptop. It keeps saying limited or no connectivity. Help?
  • 813 Answers
In your sis lapotp give a spcific ip address
for exampl
192.168.1.25
255.255.255.0
192.168.1.1
dns 192.168.1.1
Posted on Mar 25, 2008
SOURCE:
I have a D link DI 524 802.11g/2.4GHz wireless router which I've
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Jun 14, 2009 | D-Link DI-524 4 Port Wireless-G Router -...
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
DI-524 status led not blinking
Here are the instructions
  1. Make sure that you have a copy of the latest firmware and it has an *.exe file with it. Because the router's configuration page won't be available, you'll be needing the exe to some sort of force the firmware upgrade procedure.
  2. Unplug everything attached to your router except the power cable and LAN cable connected to your pc.
  3. Configure your TCP/IP with this info: IP:192.168.123.253, Default mask:255.255.255.0, Default Gateway:192.168.123.254 and DNS Server:192.168.123.254 (Use only 1 DNS server). Save this new configuration and reboot your pc.
  4. Unplug the power cable to your router as the pc reboots. When everything is up and running, plug the power cable. The status led will be flashing like crazy. It's normal.
  5. Use the exe file to upgrade your firmware. Make sure that the utility file (exe file) is able to recognize your router or else you won't be able to do a firmware upgrade. Now this may take a while, keep pressing the Refresh button to recognize your router. Once recognized you would see there 192.168.0.1 crash. Once you have this, you can now press the upgrade button.
  6. Wait for a while until the unit finishes the upgrade and once done, I think you have recovered the life of your router from the pits of hell. Hahahaha.
  7. You can now unplug the power of the router and restart your pc, see if everything is doing fine.
Hope this helps.
Also you can visit the link :: support.dlink.com/products/view.···DI%2D524 for further assistance
Please rate this solution!!!!!!
Nov 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Configuration
I have same problem. Can not connect Di 524 to Surf 5100 Cable modem
Jul 23, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link di 524
You can find all the information on routers on the web link given below.
http://support.dlink.com/supportfaq/
I hope this should help you will the router information and troubleshooting on your own.
Have a great day.
Feb 12, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
Problems with speed and local ftp on D-LINK DI-524
you may have to open the port that opensuse uses in your routers settings, this will probably be called something similair to virtual servers or within the firewall settings, you will have to enter the port number that the programme uses and allocate the number against the ip address of the pc that is connecting. The fact that you have 3 cards in one pc may confuse matters for the router,so probably dissabling two of them may prove to be another solution to the problem
Jun 04, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
59 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
