Question about Kenmore Vacuums
What is easiest way to replace electric cord that has frayed at entrance to the vacuum?
  • 294 Answers
I would take it to a qualified repair shop for this type if repair. Without knowing the specifics, most vacuums have a strain relief that needs to be squeezed and pryed out. Once this is out the cord can be replaced, but will need to have the correct type of electrical connectors and tools to make the connection. Most cords cost about $15 - $20
Posted on May 02, 2010
My Hoover UH70604 vacuum just quit running.
have u check the cord for frays specially if this is a older unit or the switch for false contacts...hope this help u.thanks
Nov 12, 2013 | Hoover Remedy Multi-Cyclonic Upright...
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    The lead on our machine is becoming frayed - is it possible to replace the lead and if so, how is it achieved? John Tuffley
    If you are refering to the Electrical Power Cord? Yes, this can be easily replaced or repaired.
    Depending upon where the cord is damaged, you can either cut it a little shorter and install a replacement electrical plug end (available at any electrical parts store (Lowes, Home Depot, Radio Shack, etc) for about $2.50.
    Or if the cord is damaged near the vacuum, you can purchase another cord or even make up one yourself how ever long you want it within reason.
    Jun 15, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
    My friend has a Tristar MG1 vacuum. The cord was
    Chances are that there is the tiniest fray of one of the wires touching somewhere. Since you have already made a good repair with nuts and tape, feel the length of the cord for other bite marks where a puncture might short the cords. If you find such a site, **** the sheath lengthwise, tape the wires and replace them in the sheath, then tape the sheath closed.
    Regards, --W/D--
    Aug 10, 2009 | Tristar Vacuums
    Have no power to unit. have cleaned everything, but still no power
    Please advise brand. Some vacuums have switches that become defective. I suggest using a VOM (Volt/Ohm/Meter) and follow the current into the vacuum. If it come to the switch, but not out of the switch - replace switch. Make sure cord is not frayed with a broken wire inside. Again the volt meter will ferret that out. If the motor has motor brushes one could be sticking or worn - replace.
    If you are not comfortable working with electricity, please consult a reliable repair man
    Mar 08, 2009 | Vacuums
    Replacing the electical cord on Kenmore Progressive Vacuum
    To the right of where the cord comes out of the machine is a large screw. Remove it, and slide the upper handle assembly free.
    Then, on the front of the machine, remove the screws located toward the top of the vacuum just inside the bag chamber cover. This will allow the front panel to be removed, giving you access to the cord from the front.
    -R
    Sep 15, 2008 | Kenmore 31913 Progressive Direct Drive...
    Kirby G5 vacuum
    check the cord. see if there are any frays. or broken spots. usually it is one of 3 things. 1, faulty electric cord. 2. the attachment or floor nozzle not being properly attached( kind of a duh issue LOL)
    3. a faulty switch assy. the switch can be kind of a bear to replace. I hope it is the cord. if not i would take it to a kirby repair person, because it is very easy to damage the motor assy when replacing a kirby switch. trust me i have damaged a few learning how to do it
    Jun 21, 2008 | Kirby G5 Bagged Upright Vacuum
    Power cord
    May need to break the unit down to replace the cord,there should be some tec screws under the belt cover to remove the motor housing cover, may be two to thee wires. the rest should be simple.
    Jan 09, 2008 | Kenmore 31913 Progressive Direct Drive...
    Vacuums Logo
    78 people viewed this question
    Top Kenmore Vacuums Experts
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
