Question about LG WM-3677HW Front Load Washer / Dryer
How to remove top of lg wm2277h washing machine to repair soap drawer
    Novelist:
  • 112 Answers
There are two philip-head screws that have to be removed from the back of the unit. One of these screws is on the left side and the other is on the right side.
Once these two screws have been removed, you will want to push/slide the washer's top panel backwards (towards the back of the unit). It might be a little hard to move at first, but it will slide backwards with a little bit of force. Once the top has move back about 6" to 10", you can lift the top off of the unit.
The dispenser is on the left side.
Posted on May 03, 2010
Issues with leftover soap and water in soap dispenser when wash is done. Cleaned dispenser and still doing it!!! PLEASE HELP
Remove the soap drawer completely, and wash it in warm water. Clean the roof of the hole where the dispenser drawer is using a plastic pot brush and some hot water. There are holes where the water comes from and they get splashed with soap.
Jan 31, 2016 | LG WM2140CW Washer
WM2277HS front loader , the drawer to put the detergent in is stuck, how do I get it open?
I have slightly different model. Tried the remove the top option. It turned out the the drawer assembly had removable top, removed to two screws that held the assembly in place, uncliped e front assymply drawer handle and cleaned out the soap deposits. Soap build up under dispenser parts had caused the problem. It seems like running the machine a few times might have cleared the soap.
Mar 14, 2011 | LG WM2277HSW XL Front Load Stackable...
I want to clean the soap and softner holders I need a manual
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
I clean mine with plain hot water and a rough towel. Then I fill the dispenser with hot water and run a light wash cycle.
Dec 31, 2010 | LG WM2277H Front Load Washer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
Dispenser wont open
The dispenser has jammed against the drawer and will need to be checked out by a qualified LG technician.  They will have to remove the top of the machine to gain access to the dispenser.  The dispenser has a top section that can be unsnapped to gain access to the drawer for removal.
Jul 19, 2008 | LG WM-2277HW Front Load Washer
Washer lg
You are probably using too much soap. You also need to make sure you're using HE detergent. To test this run the washer empty (no soap) and if you see bubbles inside that's left over soap that's still in the unit. If so, keep running it empty until the bubbles are gone then start using only about 1 tablespoon of soap per load. The washer uses about 1/10 of the water so you need to use 1/10 of the soap. Use the same amount of softner.
Jan 13, 2008 | LG WM2277H Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
Soap dispenser slow leak
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Sep 20, 2007 | LG WD-1080FD Front Load Washer
LG WM-3677HW Front Load Washer / Dryer Logo
266 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
