Question about Samsung Refrigerators
Fridge won't cool down
I have a Samsung RB1855SW - we moved it to tile the floor and now when we try to set the temperatures it won't stay cool. The freezer seems to waver around 2 and the fridge reverts to about 54.
  • Samsung Master
  • 5,568 Answers
I don't know that you did lay it on its side to move it but if you did, it will take several days for it to recover completely.
Posted on May 01, 2010
My refrigerator shows a code "OF" or "0F" where the temperature settings usually show, we tried to put the temperature settings back but couldn't. We unplugged the refrigerator to reset it but it sti
Cooling Off mode (also called Shop mode), is designed for use by retailers when they are displaying refrigerators on the shop
floor. In Cooling Off mode, the refrigerator's fan motor and lights work normally, but the compressors do not run, and
the refrigerator and freezer do not get cold.
To start Cooling Off mode, Touch and hold the Energy Saver button and the Power Freeze button for 3 seconds during normal
operation.
The refrigerator chime sounds and the temperature display flashes OF OF.
To cancel Cooling Off mode, Touch and hold the Energy Saver and the Power Freeze buttons again for 3 seconds.
Source: http://downloadcenter.samsung.com/content/EM/201104/20110414114919054/110323-QS_Guide-POLARIS-EN.pdf
Dec 30, 2013 | Samsung Real Stainless Steel 30 Cu Ft Side...
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
My air conditioner won't cool down
I Think when it goes back to 33 thats your ambient temp . the temp in the room thats its trying to get down to .
If you set it on 22 . and just ignore the 33 it does it stay on cooling ?
Jan 30, 2012 | Heating & Cooling
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
My unit works great on AC (cools to 30degree), but
Your fridge has two manual settings to adjust it's internal temperature. Obviously, it most likely has a standard control (1-5 or 1-9 depending on the fridge) that you can adjust on the control panel. Some fridges are preset (no control panel adjustment) and must be adjusted on the inside of the unit. If open your fridge, look at your cooling fins. You will notice a metal slider on a wire attached to one of the fins. Moving this sensor up or down along this fin will set the internal temperature of the fridge. You will have to play with it a bit to get it set properly (with a thermometer), but you should be able to get it to the proper temperature. I hope this solves your problem. Thanks... John Charles
Jun 12, 2010 | Dometic RM2652 Refrigerator
My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Apr 16, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Disconnecting our fridge
DO YOU HAVE A CRAW SPACE? UNDER YOUR HOUSE
Apr 05, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
331 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
