Question about Brother CS6000i Computerized Sewing Machine
Top stitche is to tight and bottom stitche is to loose
I have tried to adjust my machine but the stiches are either to tight or to loose
    Genius:
  • 1,116 Answers
Meaning you have adjusted the tension for the top thread as well as the bobbin?
Use two distinct colors of thread - one for the top and one for the bottom.
Thread the machine with the presser foot up.
The two threads should meet in the middle of the stitch with neither obvious on the opposite side of the seam.
Set the top thread tension to 4 and adjust the bobbin as needed.
Posted on May 01, 2010
Hi. I just bought this machine and I am having trouble with my bottom stiches. I have tried every remedie but the stiches is too loose
Read this hope it helps
http://www.threadsmagazine.com/item/4302/understanding-thread-tension/page/all
May 19, 2016 | Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
When i am sewing the stiches on top, but its at the bottom
change the needle --make sure it's the right one for the fabric
being sewed
rethread the machine top and bobbin
make sure the bobbin is turned the right way in the bobbin case
also check the top thread tension, if the stitches under the fabric
are loose adjust the top thread tension one number or letter higher
at a time and sew on a scrap piece of fabric till the stitches look
normal
here is a free manual
http://www.singerco.com/uploads/download/696_5417c.pdf
Jan 07, 2013 | Singer 5417 Mechanical Sewing Machine
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top thread is loose
Your needle thread tension is too tight or the bobbin tension is too loose. If it is the latter try turning the bobbin case tension adjusting screw clockwise abot a full revolution.
If that does not work there is more than likely a bit of lint behind the tension spring, so carefully remove it and clean it out.
Jul 06, 2009 | Singer 2662
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Brother CS6000i Computerized Sewing Machine Logo
348 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
