Question about Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer
How do i change the twine spool om my Weedeater Twist n Edge RTE 115
5 Suggested Answers
  • 57 Answers
SOURCE: how to install the Speed Spool Bump Knob Assembly
Do you have an owners manual? If not, try poulan.com
Posted on May 19, 2009
SOURCE: Trying to replace the line in weedeater Twist/Edgs
search youtube "change line on a weed eater" there are several videos there maybe one is similer to yours
Posted on Oct 25, 2009
  • 1514 Answers
SOURCE: I need to know how
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Posted on Oct 07, 2010
rycgl
  • 1545 Answers
SOURCE: I have read the instructions
Usually, the only instructions with pictures for repairs like this are on a You Tube video if you are lucky. They may be diagrams with instructions available though. This problem is common with these units and I just recommend taking the old head off and getting a Universal type string head at the home improvement store as a replacement. You can look here if you feel a manual with diagrams can help. This is closest thing to your model I could find. See page 7.
http://dl.owneriq.net/c/cc3d8bf0-cc46-418b-bed8-e13da682e377.pdf
Posted on Oct 31, 2010
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to respool an electric Weed Eater Trim and Edge RTE 115
The nylon string is simply spun onto the emty spool. There should be an arrow on the top of the spool indicating the direction to wind the line. If the spool is missing a notch to hold the line to get started, use your finger to hold it in place for a few full wraps.
Apr 03, 2010 | Garden
Trying to replace the line in weedeater Twist/Edgs RTE 115c. I can not get the line to feed into the spool. How is this done?
Oct 25, 2009 | Electric Garden
How do i replace a spool on the weedeater xt110. I cannot seem to get the spool to release and I do not have the owner's manual.
Just line up the two arrows across from each other to those on the the spool housing on the bottom of the spool. Then grip the bump knob and pull straight out. It takes a good grip and some force, but it usually gives way.
Jul 14, 2009 | Poulan 12" Electric Twist N Edge Plus...
Cannot get spool out of Poulin Weedeater Lite
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 27, 2009 | Poulan Garden
I can't seem to find the replacement spools of line for my Weed Eater Model number RTE 115 C. Do you have any suggestions?
lowes supply carrys a good variable supply of replacement lines different thicknesses etc....hope this helps..chris
May 13, 2009 | Garden
Weedeater quits working/button no longer activates weedeater
try this get a good extension cord test it plug it in now with the trigger pulled wiggle the cord going into the weeder i have in the past moved the cord till i got working and taped it to the handle, if that dosent work get a new one
Mar 07, 2009 | Poulan Genuine Weedeater Part # 36006-128
Poulan Weed Eater Rte115 4.5 Amp Electric Trimmer Logo
256 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
