Question about GE DBL333EA Electric Dryer
GE 333 Elec Dryer has loud, consistent (1 per revolution) sceech like a bearing gone south, but I can't even figure out how to take the top off to look down inside.Would like an 'exploded parts diagram' and a hint of how to lift the top off.
  • 10,319 Answers
The rear panel has two small brackets attached to the top. Remove the screws holding these on and the pry up the front top to open
Posted on May 01, 2010
WBVH6240FWW loud bang
that would be the bearing and housing gone on the drum, if you can lift the drum with your fingers at the bottom of the drum in the door hatch even by putting lifting inside then the bearing has gone. the plastic is the drum.housing usually were the bearing housing is. if there is a lot of movement then the bearing has gone. usually the front bearing but you will need to remove the drum and separated the drum to remove the drum then the bearing, rust on clothing is the bearing as its the only part in the drum that is metal.
Jun 27, 2017 | GE WBVH6240F Front Load Washer
My dryer makes a clunk sound twice per each revolution. I thought maybe a bearing but all seems tight???
sounds like coins are in the tub vanes...take top off dryer and remove screws that hold vanes in place...maybe coins under the vanes....seen it hundreds of times in 40 years
Sep 18, 2011 | Frigidaire FEQ1442ES Electric Dryer
Dryer makes a loud squealing noise
the rear bearing is gone,ge has a bearing kit that goes on the back of the drum and hooks onto the back wall,the bearing wears down and gets noisy,call your parts store,give them the model number and they'll give you the parts you need
Dec 03, 2010 | GE Spacemaker Washer and Dryer Electric...
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Makes a loud clunk once per drum revolution. There is a mark on the outside of the drum and I think it's hitting the motor housing. Could this be the drum bearing? Is it worth repairing? It is a IS60V
Hi, What brand is this and model #? It does sound like a bearing or rear roller has gone bad. Yes it will be worth fixing. I cam help you. Please let me know.
Thanks
Vic
May 13, 2009 | Dryers
Me GE elec. dryer is screeching, how do I solve this problem
First, stop using the dryer. It is telling you "I'm broken".
Several things can cause the noise you are describing:
1. Belt is slipping. Lost proper amount of tension on the tension pulley as spring has become weak.
2. Rear drum bearing has rubbed completely through and the drum is now riding on the metal support, This can cut into the drum support and trash it.
3. Tension pulley has got bearings that have gone dry (bad). Fix is to replace pulley.
4. Chance that the bearings in the motor itself have gone dry (Bad). Some you can oil and some are sealed. In either case, if they are making this noise, they are probably no good and motor needs replacing.
Good Luck and let me know how it turns out.
May 11, 2009 | Amana DLE330RAW Electric Dryer
GE DBL333EA Electric Dryer Logo
66 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
