Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Need to change from LP to propane. How do I get access
How do I change orifice on Whirlpool 6200 dryer
  • 494 Answers
LP and propane are the same gas. Did you mean you are converting from natural gas to propane? You can buy the conversion kit from your local appliance parts store and then hire your propane co serviceman to do the conversion for you. You''ll need the make, model and serial number to order the correct kit.
Today's dryers are not as easy to access as they used to be. They used to have an actual front panel you could remove to access everything inside, but now they only give you a peep hole and you have to take the unit apart. I don't recommend doing it yourself. Like today's cars, appliance manufacturers are making them more complicated and harder for the average person to access for repair. As a propane serviceman, you'll have to trust me on that.
Posted on May 18, 2010
    Problem Solver:
  • 7 Answers
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
Posted on May 01, 2010
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
How do i convert from natural gas to LP or Propane?
You need the LP gas conversion kit: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-lp-gas-con-item-number-ap4300853.aspx . Other sources may exist. This includes a replacement orifice and a spring and the installation instructions. The orifices are swapped with a small wrench. The spring fits inside the regulator inside the blocking plug.
You will also need to remove the cap from the regulator and turn it over. This makes the regulator compatible with LP gas. It's easy to tell which side is which - each side is labeled.
However, the conversion kit should be installed by a professional trained for the job. Your local LP dealer should be able to help you find a repair person with the skill. (Improper installation could result in a gas leak.)
I hope this helps.
Dec 09, 2010 | Amana NDG7800AW Gas Dryer
I have a lgr7646JQ whirlpool heavy duty gas dryer that was outfitted for propane but i need to change it to natural gas - what do i need to do?
You will need to change fuel orifice and possibly adjust air intake valve. Recommended to have a pro do it but if you can find original instructions, they should have step by step instructions. Also there should be an orifice kit with instructions or taped to drier housing in the back. Depending on how old the unit is and how many times it has been used the orifice may be lost.
Oct 13, 2010 | Whirlpool LGR7646E Dryer
Whirlpool duet gas to propane conversion
no you definately need to change orfices from gas(line) to propane, call your gas supplier for a conversion kit or go to an appliance parts store and they will help you on this on this matter,don't try to start this unit after change-over if the orfice isn't right, i tried it and found out tooooooooo late
Apr 04, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
COnverting it to propane
You need to change the orifice on the end of the gas valve and flip the cap on the regulator to the LP side. Model number would help.....?
Oct 30, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Changing a gas ge dryer to a propane----convertion package we25x10014 directions show a picture of the control panel with 4 plug ins at the bottom and changing out the last one on the right for the new...
Converting your Natural Gas Dryer to Lp is taking it from a lower BTU gas "Natural" to a higher BTU "LP" value. The orfice on a LP gas valve is smaller because you dont need as much gas to make the same amount of heat. make sure you change the orifice. The little plug goes in the regulator of the gas valve, changing the valve from a low gas pressure Natural to a Higher Pressure LP.
If the kit doesnt look right, did you get the correct one?
Maybe you should call you LP provider they can do the conversion for you.
Jul 10, 2008 | Dryers
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
346 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
