Question about HP Pavilion dv9700t 2.1GHz Core 2 DUO T8100 3GB 320GB DVDRW DL GeForce 8400M GS 802.11a/b/g/n WebCam... PC Notebook
Recover from failed bios upgrade - HP Pavilion dv9700t 2.1GHz Core 2 DUO T8100 3GB 320GB DVDRW DL GeForce 8400M GS 802.11a/b/g/n WebCam... PC Notebook
    President:
  • 524 Answers
Sounds rather serious, I’m afraid. Depending on your motherboard and BIOS type, that error message indicates either a failure to initialise the Display Card, or a failure to complete the memory check. Have a look at your motherboard manual and follow the instructions to ‘reset CMOS’. That may correct the problem if you’re lucky, but I’m doubtful it will.
If your motherboard has the BIOS chip inserted into a socket you should contact the motherboard manufacturer and see if a replacement chip is available. If not, you are probably confronted with a ‘dead’ motherboard. I wish I could offer a happier message, but BIOS upgrades are always a risk.
For the benefit of any readers thinking about upgrading their BIOS, here’re a few tips:
If your computer is operating smoothly, don’t do it. The main two reasons for performing a BIOS upgrade are
  1. To enable support for a new processor that wasn’t available when the motherboard was manufactured..
  2. To correct a ‘known issue’ with the BIOS for your motherboard that causes your computer to function incorrectly.
Don’t do a BIOS upgrade during inclement weather periods, when your electricity supply may be subjected to ‘flicks’ or ‘spikes’.
Try to avoid ‘Live Update’ functions for upgrading your BIOS – you’re at the mercy of your internet connection if you use them.
For preference, update from floppy disk. But be sure to use a new floppy, format it and add system files, and then perform a ScanDisk on the floppy, enabling the ‘Thorough’ option to ensure that a surface scan is conducted. Only trust your BIOS update files to the floppy after you’re sure it’s a reliable one.
Please let me know if you have any further questions or concerns.
Thanks.
Posted on May 09, 2010
I can't find the bios flash instructions .how do you flash the bios on my toshiba a35s159
You should check the Toshiba WEB site for instructions to how to upgrade (flash) your BIOS, if you make a mistake you may not be able to repair or recover from your mistake.
I have done BIOS upgrades on a few computers.
If your Toshiba has a floppy drive and you can boot up from this floppy drive then the BIOS upgrade needs to be downloaded to a boot floppy. Then boot up from this floppy and run the BIOS upgrade program. When completed, remove the floppy disk and boot up your laptop.
YOU MUST CHECK THE TOSHIBA WEB SITE AS THESE INSTRUCTION MAY NOT BE APPLICABLE FOR YOUR TOSHIBA LAPTOP.
Jun 02, 2012 | Toshiba Computers & Internet
Hello, I upgraded the Dell Vostro 410 BIOS from version 1.0.1 to 1.0.3; the upgrade was successful. Now the computer does not boot. No monitor display from the BIOS starting up and the keyboard num...
As far as I understand there is no way to recover it self the dead BIOS, You can only send it to Dell Service Center and get new Bios chip.
Maybe you need to reset CMOS, to make sure the BIOS is dead or not...
Aug 10, 2011 | Dell Vostro 410 Desktop Computer
How to upgrade BIOS in my XW400?
Upgrading the BIOS is an easy task but not recommended unless your computer has a problem which will be solved by a BIOS upgrade.
I assume that you are aware that a failed upgrade may render you system unusable till it is reloaded. Primary cause of a failed upgrade is a power failure so please make sure your PC has a back-up power source in case of a power failure.
The latest BIOS update can be downloaded from this website.
Download the exe file on your desktop and double click on run it. It is to be used on Win XP or 2000.
Before upgrading, check the version of your BIOS. If the version number is same as the one with you are upgrading, it means you have already the latest BIOS and it is not necessary to upgrade. The version number of this BIOS is 3.06 Revision A.
May 14, 2010 | Compaq XW4000 PC Desktop
Bad Bios upgrade on Dell M1330
If you cannot start the laptop, you cannot flash the BIOS. You can ship the unit to me, and I'll recover the BIOS. You can email me at buffalonymann@yahoo.com
Nov 02, 2009 | Dell XPS M1330 Laptop
My dell dimension 8400 bios a03 fails to bootup and displays this alert on the screen: Many attempts to boot the system have failed at checkpoint [Ithr]. how can i recover from this?
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Boot failure after upgrading bios asus p4xp-x
You have accidently corrupt mother board BIOS,you have to replace it ...no other choice...
Dec 10, 2008 | ASUS P4XP-X Motherboard
Upgrade BIOS
I have a QTech desk top PC i don't know which motherboard
Oct 14, 2008 | Computers & Internet
Asus r2h notebook
http://www.informit.com/articles/article.aspx?p=27188&seqNum=7
Go to the above site it may help you recover from failed BIOS update
Sep 28, 2008 | ASUS Computers & Internet
Bios upgrade error
re-install the old bios. evidently the new flash bios is not compatible with your machine.
Sep 11, 2007 | IBM Netfinity 5500 M20 4RY (86624RY)...
Ipaq h4150 failed rom upgrade (white Screen)
Pull the battery out, wiat for a minute and reinstall the battery and turn it on.
May 12, 2007 | HP iPAQ H4150 Pocket PC
HP Pavilion dv9700t 2.1GHz Core 2 DUO T8100 3GB 320GB DVDRW DL GeForce 8400M GS 802.11a/b/g/n WebCam...  PC Notebook Logo
215 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
