Question about Hotpoint First Edition FEW12 Front Load Washer
Wil not remove all water and does not rinse - Hotpoint First Edition FEW12 Front Load Washer
Have you checked the filter isnt blocked with anything, ie penny, screw, button etc.usually located at the bottom right of the machine ?. Or could be a pump problem
Posted on May 03, 2010
Why wil my washing work propley ,it will not drain or rinse or spin the water is left in there always
It sounds like your timer has failed but without a make, model and serial number its hard to tell say if you have a mechanical or an electronic timer control.
May 19, 2016 | Washing Machines
Water takes almost one hour to fill tub for wash & rinse? water pressure is alright. is there something i can check?
turn the water off to washing machine and unscrew inlet hose, now look at valve inlet to see if blocked with any debris. if so using pair of pliers remove the inlet filter and clean under the tap. if no blockage just replace the inlet valve wil def solve the problem
Nov 12, 2010 | Frigidaire Washing Machines
Gets to final rinse e20 come up wil not empty last rinse water out of the tub i can stop it dip the water out and it will spin out
  • Get the washer laying on it's side and using the access hole on the bottom carefully remove the screw clamp holding the large hole of the rubber housing to the tub drain (it will be obvious all other clips are green compression clips).
  • Carefully work the strainer out of this flexible rubber drain housing through the large hole.Clean it out and replace you will be good to go. Also remove all the hoses and check for a buildup of gunk. Hope this will fix your problem.
Thank you !!
Aug 22, 2010 | Frigidaire Affinity ATF7000E Front Load...
Dries very slow lint is clean have to run and run to dry
make sure the outlet tubes are also clean, also rinse off the lint screen with hot water, softener will clog it and not allow propper air flow, the water wil bead up on the screen if this is true, just keep rinsing till water flows freely
Nov 09, 2009 | Whirlpool LER4634J Electric Dryer
My washer will go thru the cycles but wil not drain the wash water. sounds normal but will not **** out the wash water and therefore does not add the rinse water,
It is possible that something just got stuck somewhere in the drain hoses. I'd check for that first.
Also check that the belt is turning the pump properly (most likely it is), and only do so by hand with the washer unplugged.
If it is clear of obstructions you'll need to replace the water pump. part number AP4372886 (made by whirlpool)
Oct 29, 2009 | Maytag PAV2300 Top Load Washer
Film on glasses
Try a rinse aid. JET Dry is one brand. vinegar in the final rinse can help as well. Rinse agents wil do the trick.
Oct 17, 2009 | Dishwashers
Engry problem
HI
Its true you are using power to heat the water....
BUT
all the time its heating through different temperatures, different stains are removed. Also its agitating for all this time. If you put hot water in only it wont wash as long. Also the incoming temperature could be too hot for some fabrics. Also you wil be using your hot water to do all the rinses.
Its up to you, but, zanussi know what they are doing
Feb 17, 2009 | Zanussi IZ12 Front Load Washer
Hotpoint Ultima WMA66. It goes thru the wash cycle but doesn't drain to go on to rinse/spin. It continues to turn and when the timer run's out it just stop's and is still full of water. Any ideas??
This must be a European model. If it wil not spin and water will not go out it has to be something stuck in the drain pump. You shoud have access through the bottom panel.If you have one remove it you should see drain pump.
Jul 24, 2008 | Washing Machines
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Hotpoint First Edition FEW12 Front Load Washer Logo
131 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
