Question about RCA RT2380 Home Theatre System System
I hooked it up the way the manual said and it doesnt work
I cant figure out how to install my RCA rt2380bk. how do i hook it up to a tv with a cable box?
    Brigadier General:
  • 8,546 Answers
Try whatever applies best below, in order...
Cable Box optical Digital Audio to Digital Audio In. (This brings TV-related multi-channel and normal audio into the receiver so you can hear it over the speakers. Turn TV volume OFF.
The cable box probably has a pair of stereo Audio Out RCA jacks. Run those directly to the TV so you can watch and hear cable programming over the TV's speakers without having to turn the system on. Turn TV volume UP.
Depending on your TV's Video In capabilities, use the Cable Box HDMI, Component (Red, Blue and Green), or Composite Video (single Yellow associated with the Audio Out) directly attached to the TV.
Posted on May 02, 2010
How do I hook up my ps3 to my rca colortrak?
would be best to get a old vcr, then with a cable you hook it to the vcr and play it thru the vac
Mar 03, 2015 | RCA Colortrak 2000 Tv Large Tube Screen Tv...
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )
you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
Dec 27, 2012 | Atari 2600 Console
We used rca cables to hook up the ps3 to tv and its not showing on any channels
Are you flipping thru the channels on the remote like you would for tv?
Usually what you have to do is look for a button that source or imput on your tv or controller for the Tv. that will cycle thru available imputs like HDMI 1, Cable, Component 1, RCA etc. until you find it. make sure the PS3 is on as well.
If this doesnt solve it you may have a faulty cable, you may want to try a new one if you have and see if that solves the problem, or use the same RCA cable to hook up a dvd player or other device, if it doesnt work on that device you know the problem.
Hope this helps
Jan 26, 2011 | Video Game Consoles & Games
I have just hooked up set top box to Sharp TV CX5182 and need to re-tune it? Can you send me instructions please as I can't find my operators manual. Many thanks.
By set top box do you mean a digital tuner box? If so and your tv is a newer flat panal than more than likely you wont need it anymore. That tuner will be built in. If this is the case than hook your anntena up to the new tv and go to the menu to do an auto channel search. That should do the trick. If it is an older tv and doesnt have the tuner then hook up the box the way you hooked it up before IE if you used cable than hook it up with cable if you used it with Composite cables(RCA) than use those the reason is some of those boxes you have to set that part up in the settings and that disabled the other output so if you had it set for cable than hooked it up with Composite(rca) nada, nothing would show. Once you hook it up and you see it on the screen then your good to go simple channel search from there. Also if you use cable then your tv needs to be on channel 3 or 4 if you use Composite(rca yellow red and white) then your tv has to be on the input channel that coencides with what input is hooked to.
Dec 13, 2010 | Televison & Video
I have the TV above and the cable man came out to hook-up to cable TV and couldn't figure out how to get the cable box to work on the TV turner. He had to hook it up to the auxiliary jacks on the back of...
is there a coaxial cable jack in the back of tv..(if not you may need an adapter..hook to antenna)..then set the tv to ch 3 and set to cable broadcast not air. then you will use the cable box to tune to ch.
Jun 03, 2010 | RCA F20645 TV
I have an apex dvd vcr tv the vcr doesnt work vcr doesnt work how
Video out on tv ? If yes just standard rca cables and vcr in video input mode. If no then you`re out of luck.
Nov 03, 2009 | Apex Digital AT2002S 20" TV
Hooking cable to tv
I have a protron tv and unable to hook the cable box staight to the tv. what am I missing.
Jun 14, 2008 | Protron PLTV-32 Television
Cant see the picther
check cable connections
Mar 03, 2008 | RCA DRC8335
Proscan 32LA30Q & Surround sound
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
Jan 14, 2008 | Proscan 32LA30Q Television
How to hook up a DVD player
Go to this link; http://www.amazon.com/RCA-32-Stereo-TV-F32450/dp/B00006HMDB and a short way down under "Product Details" there is a link to the product manual page 7 and 8 of the manual (page 9 and 10 of the pdf file) should tell you what you need to know. Please post again if you still have trouble; Hope it helps :)
Mar 29, 2007 | RCA F32450 32" TV
RCA RT2380 Home Theatre System System Logo
428 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
