Question about KitchenAid Classic Stand Mixer
How to replace KitchenAid KSM75WH Speed Control Lever
  • 235 Answers
Hi PC1546. Replacing your speed control lever is a pretty simple repair job. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and select “Consumer” for User Type, then enter the 6 character Model Number, in your case, KSM75W, and select the file listed under Parts List (1) KSM75WH1.pdf (341.26 KB) and save that to your computer. (Check that it matches your mixer model).
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus Nos. 1, 2, 3, 4, which are Pivot screw, Spring washer, Switch lever and stud, and Control plate spring respectively. Disassemble your mixer to the point of accessing your speed selector assembly, and inspect the pivot screw to see if it hasn’t worked itself loose over time. That’s the simplest thing to fix. If loose, tighten. Inspect the rest of the assembly to determine if something else hasn’t broken or gotten out of alignment. If something has broken, you can order replacement parts and install them yourself.
As far as parts go, here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
While your mixer is apart it would be ideal to check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Posted on May 03, 2010
Ksm 103 on one speed
Remove the back cap over the speed control and look at the speed control plate while operating the speed lever. Make sure the lever is moving the plate in and out. If yes then I would replace the small PCB above the control plate, that is the electronic part of the speed control and not worth very much at all.
Jun 15, 2016 | KitchenAid Food Mixers
Kitchenaid mixer will not run on speeds LOW SPEEDS only runs on speed ten. I've replaced the phase board and that was not the issue. what else could be causing this problem
If it does not start at all until you get to speed 10 then look for a broken wire an any of the wires NOT associated with the phase board. Highly unlikely since you have just been there. Next look at the operation of the switch low down inside the black speed control board. There is a primitive switch there operated by a shaft from your speed control lever. You may find the switch is not activating until it gets right up to speed 10. Have you checked the carbon brushes? The phase board you have just done is normally the culprit for your problem.
Dec 20, 2014 | KitchenAid KSM75WH WhiteTilt-head Stand...
Why wont my classic kitchenaid mixer switch off
Good Morning,
There is a spring inside your mixer attached to the speed control switch and speed control arm, the spring can sometimes get caught on the slide bar that is just below it inside the mixer. The other reason is that the speed control switch plate in the rear of the machine (that the spring attaches to) vibrates the three speed adjustment screws out or in and the spring will pull the speed switch (control arm that you use to control mixing speed when using the mixer) back to the stir position after you try to turn the mixer off.
If it is a spring problem you will have to do a full tear down to get at the spring and either free it or replace it. If it is a problem with the adjustment screws on the speed plate, that can be handled at the rear of the machine and is twice as easy to get at but sometimes much more frustrating to adjust. There are "YouTube" videos on the internet that will walk you through the process of adjusting your speed control plate just Google "adjusting speed on kitchenaid mixer" I hope this helps. please let us know if it does and if you have other questions just post them here and we will "FixYa"
Sep 11, 2014 | KitchenAid K45SS Classic Stand Mixer
Ksm75wh mixer stopped running
Check carbon brushes under the black caps on the motor sides. They only go in ONE way so take care, there is a blocker in the square hole on one corner. Line it up with the missing brush corner. If it's not the brushes remove the back cover & check for broken wires. Do your checking with power unplugged.
Nov 28, 2013 | KitchenAid KSM75WH WhiteTilt-head Stand...
The mixer would not come up to the speed when speed lever is moved from off position to any other speed provided. The mixer would start spinning and then stops immediately. Any suggestions?
You either need to adjust the speed control switch under the rear dome or you need to replace the switch, I think you can find on YouTube videos on how to adjust speed control switch and the part is easily available on the internet. AND!! you can do this repair without a full tear down.
Sep 18, 2013 | KitchenAid KSM75WH WhiteTilt-head Stand...
Knob for kitchaid stand mixer
I am assuming you mean the little black knob on the speed control has broken off. I will post the solution for that problem.
The speed control lever on KitchenAid mixers has a little black knob on the end (in some cases this may be white or gray). The knob is pressed onto the lever, so if the knob breaks off your only option is to replace the whole lever.
KitchenAid has a kit that will include all you need to replace the speed control lever. It even comes with instructions. Here is a link to the speed control lever kit on our website: http://www.mendingshed.com/kaleverkit.html
The lever kit includes the speed control lever (with knob), speed link, spring, instructions and a gearbox gasket.
The instructions will only walk you through how to hook up the speed control lever, so if you also need a little guidance in taking the mixer apart, and reassembling it please use the KitchenAid service manual. The manual will walk you through all of the repairs you may need on your mixer, including how to take the mixer apart and put it back together. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Remember, The Mending Shed is a Authorized KitchenAid service center, we can help you with any repair needs for your KitchenAid appliances, plus all of the parts we carry are genuine KitchenAid brand.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 15, 2013 | KitchenAid K45SS Classic Stand Mixer
Speed lever replacment
The Service manual will walk you through removing the old speed control lever in an artisan mixer, and how to put it back together correctly.
Pay attention to pages 7 and 11 as these cover the removal and replacement of the speed control lever.
Let us know if you have any questions.
Thank you,
Colleen
MendingShed.com
800-339-9297
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Hi, the speed lever won't move. I have checked that the bowl is securely placed and adjusted the height of the beaters? Can you tell me what else might be the problem. I have only had the appliance...
The Speed Control lever is linked to the Speed Link mechanism, which in turn moves the
Speed Control Assembly to allow the motor to operate at different speeds.
Get a Repair Part List from Kitchenaid.com for your particular model to see how it works.
As you select different speed setting, the Speed Link simply moves forward or backward,
thus pushing the Speed Control Assembly back and forth.
If you cannot move the Speed Control lever, means that the Speed Link is somehow bent
or out of place. Remove the Motor Housing and the End Cover and check it out.
Jul 01, 2011 | KitchenAid Artisan KSM150PSSM Stand Mixer
KitchenAid Classic Stand Mixer Logo
2,724 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
