Question about Max American Terminal 30 i Fuses
I have 94 ford explorer and I need to find the fuse that works the lights inside the vehicle so I can pull them out.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
I have 94 ford explorer and I need to find the - modified-life-logo.gif.com check this place out for car help and car audio wiring diagrams, but i think it would be under the dash on driver side. You can even look it up in the car manual in the glove box
Posted on May 12, 2010
Ware is 1999 ford explorer 3rd brake light fuse its not #13
Your high-mount brake lamp gets voltage from the same fuse as lower brake lites. Just not wired the same. If lower brakes lights work, it's not the fuse.
Jul 17, 2017 | Ford Cars & Trucks
94 Ford Explorer has starting problems. Changed out fuel pump. The problem is still there.
It could be ignition pack, under the hood, you can verify this by, pulling out one spark plug, Pull the fuse to the fuel pump, clame the threads of the spark plug to the frame of the car. DO NOT TOUCH OR HOLD the spark plug WHILE CRANKING THE CAR. This should not hurt the ECM of the vehicle. If you see a bright blue sparks, its not an ignition issue.
It could also be the spark plug wires. They should be changed approximately at 80K miles.
If there is a check engine light on, take it to a car parts store and they will read the codes, to help troubleshoot the problem.
May 28, 2015 | 1994 Ford Explorer Limited
I need a fuse panel diagram for a 1994 ford explorer
IT IS USUALLY IMPRINTED IN THE INSIDE OF THE COVER FOR THE FUSE PANEL OR POWER DISTRIBUTION BOX
Mar 13, 2015 | Ford Explorer Cars & Trucks
Why wont my 1998 Ford Explorer Headlights shut off?
Does the vehicle have daytime running lamps ? Did you pull fuse from the inside the vehicle fuse panel ? I/P Fuse # 12 30 amp underhood fuse box is for the headlamp switch . Sounds like daytime running lamp module is the problem . But , without testing this is just a guess , by looking at a wiring diagram . Do you know what a automotive electrical wiring diagram is ?
Jan 16, 2018 | 1998 Ford Explorer
Fuel pump will not engage when turning the ignition on
had this same problem with my '94. checked all other systems first. not common but possible the fuel cut-off switch may need to be reset. this usually only happens in an accident or sudden VERY hard stop. this reset switch is under dash passenger side, need to pull the kick panel. also check fuse/fuel pump relay in relay box under hood. fuse is under dash (20 amp). if all of these check OK, you are probably looking at replacing the pump itself which means pulling the tank. before you do check to see that you have power to the pump. in winter/snow/salt climates (I'm in WI) may get "lucky" and have a bad ground or shorted wire along the frame rails. these are not well protected for this climate and do corrode with time.
Feb 07, 2011 | 1994 Ford Explorer Limited
Turn signals work, but no brake lights.i have a 94 ford explorer
THE FUSE MIGHT BE A DIFFERENT ONE THAN THE TURN SIGNALS. AND THE SAME WITH THE LIGHT BULB. IT MIGHT BE A DIFFERENT ONE ALSO.
Feb 23, 2010 | 1994 Ford Explorer Limited
'94 4.0L Ford Explorer losing power
Shouldn't cost much for 10 minutes work to test fuel pressure & confirm pump condition, but do it when vehicle 's been running for a while, long enough for pump to get heated up.
Jul 25, 2009 | Ford Explorer Cars & Trucks
Pass. side trailer turn and brake lights out 1999 ford explorer
if your vehicle lights are working all the fuses will be good. follow the cable from the towing socket on your vehicle , it will most likely go behind one of the rear lights to connect into your cars system,
check your tester where the cables join and you should find the problem. hope this helps.
Apr 23, 2009 | 1999 Ford Explorer
Need diagram of 2001 ford explorer sport fuse box diagram with
it should be under the lid of each box and in the owner manual if no manual try here www.edmonds.com for owner manuals online
Mar 19, 2009 | 2001 Ford Explorer Sport
Max American Terminal  30 i Fuses  Logo
62 people viewed this question
Top Max Car Audio & Video Experts
xxxxxx xxx
Are you a Max Car Audio and Video Expert? Answer questions, earn points and help others
