Question about Sylvania 6427TE 27" TV
Sylvania Superset II Closed Captioning
How do you turn the closed captioning on? Is this a possibility, or is it a feature this TV does not have? I have tried looking thru the set up menus and have had no luck finding it?
  • thejacobson Mar 25, 2008
    Anyone know if this model has a closed captioning option? I can't find it........
    Sergeant:
    Champion:
  • 375 Answers
Is there a cc button on your remote hand unit.if not its in the setup menu .
Posted on Mar 25, 2008
How do you turn on closed caption on apex digital flat screen tv?
not all sets have the capability, not all programmes have captions.
This tell you how to turn OFF, but just choose ON.
http://captionmax.com/resources/turn-off-captions/
and I found this
Best Answer: There are two types of closed captions; analog and digital. It's possible that you turned one off and not the other. Some sets will only allow you to access the menus for the type of signal you are watching so make sure you are tuned to the offending channel when you access the menus.
Also, you might want to check other devices that the signal may go through on it's way to the TV like cable boxes and DVD players. Sometimes those have closed caption decoders, too.
Source(s): Broadcast Engineer for 30+ years.
Captioning Services Turn Off Closed Captions
Jun 11, 2016 | Apex Digital Televison & Video
Don't know how to activate closed caption, and cannot find instructions
What is the TV source? For some sources (set top box), you may need to turn on the captions using the menus of the box.
Assuming you are using a source that gives captions that the TV can interpret, if you have the Proscan 26LA30Q remote, press the CC button to toggle through the caption options. Another route is to press Menu (either on the remote or the buttons on the side of the TV) then select the Feature submenu with the left/right arrows. Press Enter (menu when you use the buttons on the TV) then navigate to the Digital Closed Captions option. Here you can set the captions to on and adjust the size, style and color of the captions when they appear on-screen.
If you are using a universal remote, try the CC button. If it doesn't work, try another code for the Proscan TV on the remote. There are some codes that may not control all of the functions of the TV with the remote.
Crutchfield has the manual for the TV on the product site: http://www.crutchfield.com/S-Kaec3gBqVtM/p_68326LA30Q/Proscan-26LA30Q.html . The direct link is http://a248.e.akamai.net/pix.crutchfield.com/Manuals/683/68326LA30Q.PDF .
I hope this helps
Aug 18, 2011 | Proscan 26LA30Q 26 in. LCD Television
How do I remove the printing of the conversations on my tv
It will depend on the TV and the source. If you are using the tuner in the TV, look for a CC button on your remote. This should let you toggle the captioning off. (Some TVs have options of CC On, CC On when Muted, and CC Off.)
On some TVs this can also be reached through the On Screen Menu (press Menu on the TV or remote). Then look for a Setup, Settings or Options menu. Then look for Captions and turn them off.
If you are using a universal remote that has a Closed Caption button that doesn't work for your device, it could be a code mismatch. Check if there are other codes for your device manufacturer and try using them to get all the features of the TV controlled by the remote.
If your source is a set top box (satellite, DVD player, cable), then you may need to disable the captions through the settings of the box. (Again try the menus.)
There is an exception. If the source is one that is using Open Captions, then the Captions will remain on.
Please add a comment with the TV and source for a more specific way to turn off the captions for your system.
I hope this helps.
Aug 15, 2011 | Televison & Video
Our LG 42LH30 TV for no reason displays closed caption. We cannot turn this feature off as when you try to select it in the set up, it is grayed out and skips past that option to turn off
What is the source of the signal for the TV? The CC may be turned on at the set top box (cable, sat, dvd player). Check the menus for any of these devices. If the source is OTA, then I'm not sure what to suggest.
I hope this helps.
(I have dealt with this for a neighbor. To get the captions on an older TV, they need the captions turned on at the satellite dish receiver and put the system in single mode. So they have to remember to turn off the captions when their hearing impaired relative leaves.)
Jan 24, 2011 | LG Televison & Video
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Turning on closed captioning
Some older telivisions don't have the option hoever caption with always be under the menu. Or if your playing a DVd then under the language set up.
Feb 12, 2009 | JVC AV-20220 TV
New Toshiba 37" flat screen always displays Closed Captions. Feature is turned off with TV remote, feature not available on Cable remote. Toshiba says it is Cable company problem, Mediacom cable can...
I've had this problem for a bit, it seems that there are two ways to turn off the closed captions.
1:Menu--->Preferences--->CC and Digital Audio Selectors. This displays the menu on the bottom of the screen with the choices of Closed Caption formats and digital audio. This is not the correct menu to be in. This turns off the CC as long as the TV is not turned off or the input is not changed. This is a temporarily either turns the CC on or off.
The Solution:
2:Menu--->Setup--->TV Settings--->Closed Captions Settings Displays a menu in the center of the screen, with the options of Turning the Closed Captions on and off, the Analog CC Mode and Digital CC settings. You must turn the Closed Captions off in this menu or the changes to CC are temporary.
For the record:
1. I'm aware I'm 2 years late on this, but I just want others to be able to solve this issue on their Toshiba. Don't worry, my Toshiba is the same age as yours
2. I've lost faith in Tech Support ages ago. I'm sorry that they were that incompetent.
3. Its ridiculous that there are two entirely different menus to alter the closed captions. Took me forever to figure this out.
Hope this helps you and others.
Jun 17, 2008 | Televison & Video
Black Box On Screen
Salutations Cranberries,
The annoying black box is usually a feature of the closed captioning called "Text" You should be able to go in to onscreen menu and select caption options. Unless you need to have the closed captioning on for medical reasons, it maybe best just to turn off all captioning options.
Hope this helps.
Jon
Go Ahead. Use Us.
May 27, 2008 | Sansui CDVD1300W 13 in. TV/DVD Combo
Sylvania 6427TE 27" TV Logo
287 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
