Question about KitchenAid KUDS24SE Built-in Dishwasher
I have a kitchenaid dishwasher model kuds24se with a problem. I MUST hit cancel before I hit start. Note that it doesn't matter how long it's been since the last cycle. It could be a few minutes or a day or more. I have to hit start to get a complete wash cycle. If I don't hit cancel, the washer goes through some sort of cycle and stops. It seems like a normal cycle but of course it is not because I don't hear any water and, upon completion, when I open the door there is heat but the soap dispenser has not opened and the dishes are filthy (again as though there wasn't any water). If I hit cancel, there is a few second delay and then it goes through some sort of cancel cycle. Upon completion of the cancel cycle, if I hit start the machine will go through a complete cycle correctly which is to say the soap dispenser opens and the dishes are spotless.
  • 725 Answers
SOURCE: kuds24se dead
check the black and white wires that come from the plug. be careful but it sounds like a bad control..
Posted on Sep 22, 2007
SOURCE: Kitchenaid dishwaser poor cleaning KUDS24SE
There are 2 likely candidates. The first is the chopper - the device that grinds up the food. The second is the check valve - a rubber flapper that sets to the right of the chopper. Over time it becomes stuck open which reduces pressure at the spray arms.
Good luck - I had the same issue on my KUDR01J.
Posted on Dec 17, 2008
  • 72 Answers
SOURCE: KitchenAid Dishwasher Model KUDK03CTWH2 Soap Door won't open
Posted on Jul 01, 2009
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Posted on Dec 21, 2009
  • 43501 Answers
SOURCE: Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
Posted on Sep 30, 2010
Start button not activating my kitchenaid sculptura dishwasher
Yes the control panel (also called switch panel) can be replaced.
Refer this site for details. You are probably referring to item 3 in the diagram.
Oct 30, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
Kuds24se dead
HAve you check the power supply to the control panel? you may need to open the panel and check the circuit.
Sep 18, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Wont drain
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Aug 01, 2011 | KitchenAid KUDS24SE Built-in Dishwasher
I have a kitchen aid KUDS24SE dishwasher that I believe has a piece of glass stuck in the chopper. How do I get to it? I have the impeller out is there a repair manual online somewhere?
there will be a screen inside pump where food chopper sit here is a link showing the full schematic for your dishwasher piece by piece taken apart just choose the section and examine the sump area and you will be able to see how to get to the chopper If you have any further questions message me back and please remember to rank this opinion as to how it helpedin your appliance situation Thanks again
heres the link
Dec 09, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Our kitchenaid dishwasher model: kudio1lbl6, doesnt work. no lights, there is power at its box
Dishwasher does not work. The power is on but when you push start it doesnt go on. When you hit cancel it goes on for a few seconds then shuts off.
Sep 04, 2010 | KitchenAid Dishwashers
The rinse dispenser no longer dispenses rinse agent. Glasses are now cloudy. Is it a matter or replacing or repairing the device.
there is a kit to fix the dispenser but as a tech it is better to replace let me know if info has been helpful
Feb 23, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
KUDS24SEB3 - can't start cycle properly
I just had the same problem. I finally pressed Rinse Only and it started to fill. Without canceling, I depressed Normal, and it seems to be going through the proper cycle now.
Sep 17, 2008 | KitchenAid KUDS24SE Built-in Dishwasher
KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
