Question about Bosch Axxis WFL 2060 Front Load Washer
Looking for a repair manual for Bosch WFL 2060. Drum will not spin. Think it might be belt as it sounds as if it going through the cycles. Water will drain
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
mnwarfield10
  • 452 Answers
SOURCE: The drum stopped turnig and there seewms to be no
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Posted on Dec 30, 2009
Testimonial: "spot on thank you"
SOURCE: bosch wfl 2050/2060 washer door is jammed and will not open
talked with bosch rep-- said there is no manual door release
Posted on Aug 23, 2010
Macmarkus
  • 2605 Answers
SOURCE: Bosch WFL 2060 GB - The Drum does not rotate, I
Welcome to fixya.
Follow this link and though it may differ slightly, the procedure is the same.
http://www.fixya.com/support/r5082734-yes_change_some_bosch_washer_motor
Thanks for choosing fixya and good luck.
Regards,
Macmarkus :)
Posted on Oct 22, 2010
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2050/2060 washer door is jammed and will not open
Jul 25, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Motor not turning at all. Water goes in and pumps
Since you say relay sounds are heard, it shows the command is OK. The power to the motor is not reaching. It could be relay contact problem.
If you have a option of only spin, try this option. If it works the motor is OK. Otherwise you have to trace the power line and test it through a electrical line tester.
Apr 01, 2010 | Bosch Axxis WFL 2060 Front Load Washer
1. Too much vibration on spin cycle even on
loud rumbling noise when running, unplug it, take the rear cover off and remove the drive belt. Then turn the inner drum by hand. If there is a grating noise, the bearings will almost certainly need replacing.
drain port take out and give a very good clean with warm water and makes sure all the holes are cleaned right through
Mar 09, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Drum Does Not Turn
The belt that turns the drum has broken.
Mar 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Won't spin - belt fine!
I had the same problem with my Bosch 2060, which is almost 6yrs old. After opening the back of the washer and inspecting, belt looked good and not loose. Spending several hrs on net looking for postings, most thinking replacement of motor brushes is the solution. Someone posted that the connector on the right side of motor (located under the tub) to the right side could be loose. I pushed on the connector to make sure it was tight. Powered up and went to spin cycle and was greatly relieved that washer began to spin. Thanks for whoever posted this simple fix.
Jan 07, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2060 front load
bad belt bad motor bad motor control unit bad ccu or wires un plugged if you can hear the motor rum check belt one time i had a nail jamming the tub through the holes in it like to never found it in that stainless steel tub lol
Dec 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
455 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
