Question about Teledyne Laars Teledyne_ Laars Lite2 Electronic Ignition 125,000 Natural Gas Heater
I have the Teledyne Laar EPS -250 . This problem started about a month ago. My heater comes on for about 15 minutes then shuts off. It will then keep igniting and shutting off ever minute or so.
    Genius:
  • 1,416 Answers
from your statement above this means that the element that is the heat provider of your teledyne have develop weakness in it function
what you need to do from here is that open your teledyne laar with the technical tools then trace the maize i.e the wire that is connected to power to the element remove the wire connected to the element (heater) remove the old element and get another new one to fix it up then your heater will work fine again.
please do this with care and make sure that when carrying out this function all form of power supply should be disconnect from power in order to avoid electrical accident or any form of it
to locate heater from the from your teledyne laar it always in black or brawn in colour
Good luck and thanks for using fixya.
Posted on May 01, 2010
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LLD400NB natural Gas
if wired 120 volt change fenwal from 220 volt to 120 volt if it takes like 3 times to lite
Feb 05, 2013 | Teledyne Laars Pool & Spa
Pool heater kicks on and off
safety switch is opening and closing, or issue with gas valve coils
Sep 17, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars N G pool heater keeps shutting off then restarts
check gas pressure and the size of your line if too small a line and too long a run from the meter it will run out of gas in line then line fills back up heater fires and drains line again
Jul 25, 2012 | Teledyne Laars Laars Lite2 Heater 175000...
I have an older Teledyne Laars EPS Gold Series One pool heater. About a year ago, I had a new Jandy igniter installed. Now, the pilot light goes on and simply burns -- it does not ignite the full burners...
You need to see what what pressure is required to turn the heater on. If you don't have enough flow or pressue, the heater will not ignite. Was it working before?
Sep 28, 2010 | Heating & Cooling
Pool heater laar 350000btu
There are a number of things it could be. Check for an open High Limit switch. If that is okay, check the thermostat. If there is a way to use a jumper wire around it without hurting other componets, do it. If that is not the problem, I would look at the gas valve. That will be the most expensive part so try the others first. If you change the valve and it does not cure the problem, you may not be able to return it. Good luck...Lee
May 28, 2010 | Teledyne Laars END CAP - 10403800
Pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Teledyne lyte 250 will work intermittantly
have u clean t filter ? if continues check where are u loosing 24vac after the transformer there is the problem
Sep 13, 2009 | Teledyne Laars Pool & Spa
Teledyne Laars Teledyne_ Laars Lite2 Electronic Ignition 125,000 Natural Gas Heater Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
