Question about Ricoh Aficio 2020D Copier
SC551 error on Infotec IS2220D same as aficio 2020D
Hi, after moving our infotec to a new warehouse we started getting this error SC551. The guy from infotec service checked the machine and says the power suplly needs to be changed ?!? He look like he really didn't knew what he was talking about.
I'm sure the psu is ok, something must have shifted when moved. The machine only has 8000 prints on the counter but no warranty.
  • 3 more comments
  • Milan D Mar 25, 2008
    SC551 stands for Pressure Roller Thermistor Open
    Infotec IS2220D machine should be similar to:
    Ricoh Aficio 2020D
    Gestetner DSm 620D
    Nashuatec DSm 620D
    Rex Rotary 620D
    Lanier LD120D
    Yes but do i have to take all capacitors of the print to test them ?
    none of the is bulged and the most of them show decreasing voltage when mesured. They should be ok , right? One of them has no voltage and shows a fixed resistance arround 1300 ohm. This looks suspiciuos to me of is it because of other components on the print plate?
  • Milan D Mar 30, 2008
    do you mean like a schematic from the manufacturer. I don't think this is easy to find.
    Isn't there a easyier sollution like changing all the capacitors on the PSU or the full PSU by example. And is it sure it's one of the capacitors and not something else? The machine starts booting and after 10 seconds only (self check?) gives an error.(sc551) Some functions still work, like the counter by example. I gues if there is some problem with the psu the whole thing won't boot.
  • Milan D Mar 31, 2008
    They already sent a guy who really didn't knew what he was talking about. At the las he said "hes papers told him" he should change the PSU and that would cost arround 750? (?!?) (+/- 1.000) For that money i got a new one. But the problem is my copier only has 8.000 prints on the counter so i really don't want to throw it away.
    Can't i just exchange the PSU my self ? I'm sure it will be cheaper. But is it sure it's the PSU?
    Genius:
  • 3,587 Answers
This ought to be truly done with a schematic and voltage level chart or diagram, don't you suppose?
Posted on Mar 30, 2008
  • Patrick Michaels
    Patrick Michaels Mar 30, 2008
    voltage levels are critical on this unit. Any variation, would show as a soft value, hence your Thermistor situation.
    well, sounds like it's time for a service call, friend.
    Guru:
  • 1,894 Answers
It must be a small damage in capacitors in power supply
Posted on Mar 25, 2008
  • dewan nafees ahmed Mar 25, 2008
    you will have to have a visual check up for capacitors with bulged heads.
    sometimes if the problem is in bottom side then you will have to find it with a meter only
SOURCE:
Error code sc320 showing on infotec 4151mf
That is a polygon motor error.
This motor is from the Laser Unit. Probably you have to change it.
If you do not have technical training i advise you to call your provider.
Mar 11, 2011 | Ricoh Aficio 250 Copier
Error code sc202 on infotec isc615g
SC202 is a problem with what is called the polygon motor, It is the motor in the laser unit and has most likely failed.
Jul 14, 2010 | Ricoh Aficio MP 161SPF Color Copier
Infotec 5221dz when machine starts up it all
Check the sorter and exit part gears.Remove the sorter unit and make a copy.If the machine worked the problem is in the sorter unit,if not workwd the problem in the exit unit.If the sorter is defected you need to de-reassambly the unit,checked the mechanical components,sensors,motors and gears,and realignament the bin sections.For more information and suggestion please contact me.
Oct 10, 2009 | Ricoh Office Equipment & Supplies
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Fault SC546
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Jan 12, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Infotec IS 2220D Copier (same as aficio 1022 i think) SC551 Error
Start by pressing clear modes, 1, 0, 7, and press and hold clear/stop. enter copy sp, select 7 fot data log, scroll to 7807, and execute. exit all the way out, and recycle the power. See if that does not fix your problem.
Mar 25, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Printer/fax problem
whats the make of the copier ie: Ricoh, Canon
Jan 09, 2008 | Office Equipment & Supplies
1,184 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
