Question about Breville ESP8XL Espresso Machine
How do I fix a leak from the coffee holder unit
Breville ESP8XL espresso machine: How do I fix a leak from the coffee holder unit (that is, from the part into which the pod holder fits)?
    Problem Solver:
  • 11 Answers
Typically one of 2 things:
-busted silicone gasket (i order from breville)
-busted filter ring holder (i bought an aluminum one from www.vancouverwireedm.com/caferomadiyt.htm for $55 - delivery took 2 weeks but it fixed the problem
Posted on Aug 13, 2010
    President:
  • 1,618 Answers
Does it leak around the pod holder, or after the holder is removed?
It it is around then you need to replace the head gasket.
If it is after then the solenoid or the valve seat is damaged.
Posted on May 04, 2010
    Problem Solver:
  • 15 Answers
Breville brew head seals are rather difficult to locate, but I personally stock them for ESP8XL & 800ESXL machines and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups and some Breville. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Posted on Nov 27, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
I've A Breville 800 esxl espresso machine.when making an espressothe machine starts leaking from the external slots outside coffee filter holder.what is the cause of it?
May 21, 2010 | Breville Die Cast 800ESXL Espresso Machine
Breville Cafe Roma esp8xl
push down on the water reservoir. ours took a while to prime.
Aug 15, 2009 | Breville ESP8XL Espresso Machine
Esp8xl
probably a short has melted plastic around wiring; i wouldn't use until fixed.
Dec 06, 2008 | Breville ESP8XL Espresso Machine
Cafe Roma Expresso/Cappucino machine
My understanding is that this is normal with units like the ESP8XL which use a pressurized portafilter. Non-pressurized units will leave a dry puck of used grounds.
Nov 28, 2008 | Breville ESP8XL Espresso Machine
A lake of water
anyone else w/ this problem: cheap workmanship = cheap, malfunctioning machine. turn it upside down, unscrew the 4 screws w/ metal washers and the six screws with out washers from the base of the housing. once removed, you can see that cheap metal clamps are used around the plastic hoses which supply water from resevoir to steamer & brewhead via the pump. either length of hose above pump or below pump has come loose or pump is fauly or there is a hole in a tube. good luck!
Nov 11, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Cafe Roma does not pump, or build up enough pressure to push the water through the coffee. Help.
Make sure the filter is clean, that in the holder and in the machine. If it is clean then i think your pump have to be replaced:-(
Jul 21, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
1,532 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
