Question about Nokia 6300 Cellular Phone
Micro SD Memory Card Corrupted
I have 512mb Micro SD Memory Card which ive been using for the past 5 years.
I had MicroSD Memory Card on my Nokia 6233, somewhat when i tried to open it, it said corrupted and needs to be formatted. I cancelled it and then tried to open it back again but it wont let me, and i cannot find an option to format it. I tried on different phones, sometimes it does not show up and sometimes it says Memory Card not formatted. There is no option to format it. I tried every possible way to format it, like connect to PC, it detect my memory card, when i right click it, the cursor freezes and then it says There is no disk drive or Insert disk drive. Also the memory card adaptor gets extremely hot when i plug it in my PC, its not the only one, i have several adaptors and they all get hot, I also tried it on my laptop and i still get the same problems.
Somebody please help, how can i format my memory card, it has no warranty on it cos i purchased it 5 years ago. Im sure there is a solution to this im sure it can be formatted in someway but i do not know how.
    Problem Solver:
  • 10 Answers
Try using a tool called formatter it just replaces the 01010000 whatever codes all to 000000 this'll do the trick hope this helped u
Posted on May 01, 2010
2 Suggested Answers
SOURCE: 6233 Micro SD Adaptor cannot work!
u might have set a password to your micro sd card
remove the password n use the adapter
it'll work
Posted on Jan 17, 2009
I want to download a music to my microsd
insert you memory card to computer, use card reader
at computer open windows explorer
chose the music that you want to download to micro sd
then right click chose copy
go to micro sd drive then right click then chose paste
done
Feb 24, 2011 | SanDisk 4GB microSD High Capacity Memory...
My memory card is showing in nokia 3110c mobile it is not showing in samsung E250i can u tell me y?and give me solution for this proablem plzzzzzzzzzz
According to the specifications it is suppose to take up to 2gb Micro SD cards.
Therefor the only reasonable explanation will be the fault might be with the card since you had it in Nokia 3110c it might effect the compatibility with Samsung.
What I would suggest to format the SD card with a PC or card adaptor to PC and put it directly into the Samsung and test it. Also test another card that has not been used before to see if that makes a diference at all?
And if all else fails try a smaller card because allthough the specs say up to 2gb some phones just can't handle it and you might have to try a 512mb or 1gb Micro SD card.
Hope this helps
Feb 02, 2011 | PNY 2GB microSD Memory Card
2GB microSD Memory Card memory card is corrupted memory card is corrupted
If its corrupted then simply down load hp format tool software. its free google it and downlaod.
install the software and format the micro sd card it will work fine,
Jul 30, 2010 | SanDisk 2GB microSD Memory Card
Corrupted microsd card
well ry connecting it to your pc and format it!!1
May 31, 2010 | SanDisk 4GB microSD High Capacity Memory...
Where do i find the micro sd on the nokia 6300
Insert a microSD card
Use only compatible microSD cards approved by Nokia for use with this device. Nokia
uses approved industry standards for memory cards, but some brands may not be fully
compatible with this device. Incompatible cards may damage the card and the device
and corrupt data stored on the card.
1. Remove the back cover of the device.
2. Insert the card into the microSD card slot with the contact
surface facing down, and press it until it locks into place.
3. Close the back cover of the device.
Remove the microSD card
Important: Do not remove the memory card in the middle of an operation when
the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
You can remove or replace the microSD card during phone operation without switching
the device off.
1. Make sure that no application is currently accessing the microSD memory card.
2. Remove the back cover of the device.
3. Press the microSD card slightly in to release the lock.
4. Remove the microSD card from the slot.
Nov 28, 2009 | Samsung SGH-D900 Cellular Phone
I am not able to format my micro sd card.
try to format it using ur phone.. if still showing sum error thn card is corrupted.. it will be replaced
Sep 06, 2009 | SanDisk 4GB microSD High Capacity Memory...
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
i forgot my password...pls help me unlocked. i have got nokia 6233with 1gb micro sd. i tried to give password for the sd card. but it doesnt worked. i tried it many times. one day my phone automatically got switched off. when i switched on the phone the sd card was locked and it was asking for the password..i tried many passwords but not able to open it.. what shall i do npw . is there any software or something to open the sd card.....anyone please help me.......Solve This!
I have the same problem
Aug 23, 2008 | Nokia 6151 Cellular Phone
Nokia 6300 Cellular Phone Logo
261 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
