Sound level on a sanyo pdp-32xs8da problems? setting sound level to 4 is to loud and level 3 there is no sound? pls help.
  • nathsninja May 01, 2010
    sound level on a sanyo pdp-32xs8da problems? setting sound level to 4 is to loud and level 3 there is no sound? pls help.
    thanks heaps 4 your help with this problem
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using RCA component cable or vice versa. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. If this all didn't resolves the issue then it is an Audio IC or bad speaker(s) connection. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 01, 2010
  • 11,896 Answers
Sounds like it may need a firmware upgrade. I would check manufacture's site to see if there is one available. If none available, a new sound board or chip may need to be replaced
  • Nate Stansfield
    Nate Stansfield May 01, 2010
    Not a problem! thank You for using Fixya! Come back anytime!
Sanyo DP26649 screen blacks out and sound becomes loud static
Most likely you will need to get a diagnoses performed on the set. Your problem could be with either the main board or power supply board. The million dollar question is do you repair or replace? With parts and labor to repair this set, you could come out cheaper replacing it.
Jan 15, 2013 | Sanyo DP26649 26 in. TV
My Sanyo PDP-42H2W TV WON'T TURN ON AT ALL, HAS BEEN MOVED, DID I JAR SOMETHING
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jul 18, 2012 | Sanyo Televison & Video
WHEN I TURN ON MY SANYO 32xs8da stand by light flashes
Check the power supply for a couple of bulged caps that need replace, or just replace the power supply module.
Mar 04, 2011 | Sanyo PDP-32H1A 32 in. Plasma Television
Sanyo PDP - 32XS8DA Won't power on - red indicator turns blue when pressing "on' button (remote) - after 5 secs goes back to red.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Jan 01, 2011 | Sanyo PDP-32H1A 32 in. Plasma Television
What is loud sound suppressoion
It is a dynamic range compression feature. Due to the widespread abuse of Dolby and other digital dynamic range features, normal listening levels may be interrupted by VERY LOUD explosions, etc. which may not only wake you up, if you fall asleep in front of the set but can make your neighbors very annoyed. To counteract this, a loud sound suppression feature, sometimes called "Late night listening" is offered to limit the loudest sound you will hear.
Jan 09, 2010 | Sanyo DP42848 LCD TV
Tv comes ON but no picture
the light source is out. the new lamp will cost around 250 easy fix.
Jun 04, 2009 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Vertical is 3/4 of normal size
i have had this type of problems,
check the electrolitic capacitor, charge, if it does not improve change a verticle ic.
Apr 18, 2009 | Sanyo Televison & Video
To set sound louder in samsung sgh f250.
The code is: *#0206*8378#
Then go in: H/W Test > Audio Settings > MP3 spk
change 'ear gain' to 14.
Then, enter 'Rx vol.'....
I made this changes:
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
I made this changes and the sound of mine became very loud now...
You can do your own changes, but don't abuse.
Jan 11, 2009 | Samsung SGH-e315
To increase up volume
Level 1: 150
Level 2: 180
Level 3: 210
Level 4: 260
Level 5: 300
Level 6: 370
Level 7: 460
Level 8: 550
Level 9: 640
Level 10: 700
Level 11: 800
Level 12: 1000
Level 13: 1350
Level 14: 1400
Jul 21, 2008 | Lands Phones
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
