Question about HP OfficeJet 7410 All-In-One InkJet Printer
Always feeds a second sheet
My 7410 has worked well for some time. Now when recieving a fax it always feeds a second sheet, mostly blank, but some times with just the header line printed.
    Scholar:
  • 141 Answers
You may need to repalce your pick-up roller and your stop roller
Posted on Mar 25, 2008
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
When receiving a fax, it seems that several pages of paper always
you mean you're getting 1 or 2 extra sheets when machine is printing faxes? Feed roller and separation pad that pull paper from the tray are worn.....cleaning will help in the short term.
Feb 22, 2009 | Canon FAXPHONE L80 Laser
Sometimes two sheets feed in instead of one.
Most faxes have a rubber separation pad which is designed to stop multi feeding. It is in the feed area.
They vary in size  but can be up to an inch square.
If they get dirty they can slip and allow more than one page to feed, if this happens you can clean it with a damp rag with a bit of detergent on it . If this does not work (give it three or four tries) you will have to replace the separation pad
Dec 14, 2008 | Panasonic KX-FLB756 Plain Paper Laser Fax
Sending one printed fax, yet reciever gets additional 3 blank sheets.
Open up the document feeder and look for a trapped down or sluggish switch
Oct 25, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Fax sending and recieving problem
Your fax machine probably has what is known as a "separation pad". This is a part near the rubber roller thst starts the blank paper on its way through the machine. It is supposed to let only one sheet through at a time but when it's surface wears, it doesn't function properly. A service technician is needed to replace the part.
Jul 16, 2008 | Canon FAXPHONE L80 Laser
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Copying
It seems to me that the tray sizes are not programmed correctly. A4 size is european and and slightly longer than letter size. If programmed to A4, the unit will behave as you described.
Sep 06, 2007 | Dell 1600n All-In-One Laser Printer
CONFIRMATION SHEET BLANK
THE TRANSMISSION REPORT/JORNAL SEEMS HAVE GONE OFF, PLEASE SET PRINT ALWAYS. HAPPY FAXING OMNIPRESENT
Aug 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Grabs two sheets when sending a fax
Sounds like it just needs to be cleaned. If you can give me the make and model of the fax, I'm sure that I can find the manuals for you.
Mar 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
