Question about Amana NDG7800AW Gas Dryer
I have an Amana model NDG7800AW. A few weeks ago
I have an Amana model NDG7800AW. A few weeks ago the dryer started warbling when heavy loads were inside and now it has trouble starting. If I spin the drum and hold the start switch it will start but often stalls after a few minutres and stops turning.
  • 10,319 Answers
The roller to the belt tensioner is binding causing to make the warbling noise.The bearing needs to be replaced which comes with the roller. A new belt is advisable as well when replacing. The stalling problem could be also from the belt being stretched or the timer relay is weak
Posted on May 01, 2010
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
Dryer will heat but seems to overheat and shut off.
If that is the style with the small heater in back up top the blower wheel is probably slipping.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2013 | Amana Dryers
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Amana ndg 7800 aww manual
The Amana NDG7800AWW dryer is sold at Sears. Thus Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/5976/AMANA-Residential-Dryer-L0503038 . The direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0503038.pdf . (The manual covers several dryer models.)
I hope this helps.
Jan 30, 2012 | Amana NDG7800AW Gas Dryer
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
My Amana NDG7800AW Gas Dryer won't heat up. The dryer is about 5 years old and we have no problems with it until now. Any suggestions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 10, 2010 | Amana NDG7800AW Gas Dryer
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
It takes hours to dry small load
dud thermal sensor, the temperature is shuttimg off too low
locate, replace the thermal sensor just 'downwind' of the flame
Mar 26, 2008 | Amana NDG7800AW Gas Dryer
It takes 3 hours to dry one load
vent restiction look over the back of the drier and see if the vent is mashed folded etc then turn drier on go out side to where the hood is see how much air is comming out if very little find out whats blocking it
Dec 31, 2007 | Amana NDG7800AW Gas Dryer
Amana NDG7800AW Gas Dryer Logo
164 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
