Question about Dryers
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
  • 23 Answers
You may want to check your dryer vent when they become clogged due to obstruction or bad routing you can end up with warm damp clothes.O7OUT
Posted on Apr 19, 2012
    Problem Solver:
  • 7 Answers
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
Posted on May 01, 2010
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Whirlpool model gg9878lw ---dryer heats at stat of cycle but runs longer than an hour with some clothes coming out still damp. lint filter is clean.
the gas valve coils need to be replaced they will open the gas valve when they are cool but as machine runs gas valve coils dont work since they are failing when they are warm to hot
Jul 20, 2011 | Whirlpool GGW9878P Gas Dryer
Clothes not drying. Dryer feels hot but clothes remain damp through several cycles.
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Dec 28, 2010 | Whirlpool Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
My Whirlpool dryer suddenly leaves clothes damp
Be sure to check the thermostats...they can cause this problem
Sep 22, 2009 | Whirlpool Dryers
The dryer is not staying hot to dry the clothes.
Sounds like the overheat is tripping, usually due to lint clogging the exit inside the dryer and inside the pipe.
Jun 30, 2009 | Whirlpool LGR4634P Gas Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Mar 12, 2009 | Kenmore Dryers
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
292 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
