Question about Dell Vostro 1700 Notebook
The monitor on my Vostro doesn't work. i can use an external monitor to work. has there been a common problem i can try to fix?
    Guru:
  • Dell Master
  • 1,705 Answers
You're external monitor means that the motherboard and graphics card/chip are good.
I take it have done this your are happy using the keyboard switch between internal and external monitors.
That leaves a failed or badly connected LCD screen.
First disconnect all power, remove batteries.
If its like other Dells, there's a plate between the keyboard and the screen hinges.
Check for screws first, but these plates can often be removed by, very carefully, prising this plate off. it just clips into place.
Once removed, look for screen connectors, invariably ribbon connector with a wide thin plug at the end, make sure they are home properly. One is the screen anther is for the inverter.
If you don't find the connectors there, they are probably under the keyboard.
After this, if not successful, I would suggest going to a repair shop.
Posted on May 01, 2010
    Problem Solver:
  • 16 Answers
I think ur laptop screen lamps are not working.open its back and remove its lamp module and clean its points with rubber and put it again in ur laptop maybe it will be ok otherwise change this module..
I turn on dell vostro 1520 and screen is blank. Screen shows to activity at all. On status bar between keyboard and screen POWER, CAP LOCK AND + indicator lights are lit solid. The NUM LOCK indicator is...
Attach to external monitor, if it works, there is a fuse that is blown near the video output cable. Not big enough for a novice to fix.
If not shown on external, it is a dead lcd, or bad solder ball issue. Quite common on those models.
Fuse details may be shown on my webblog. "Getting In Too Deep" Google it. Then search for Dell - it should come up in the list.
Jun 23, 2014 | Dell Vostro 1520 Notebook
On 5 sec after off laptops
You could try to start the computer in safe mode, to see if this is driver issue. When starting computer, press down F8 and select safe mode startup. If monitor works in safemode, try to reinstall display driver.
Also you could check with external monitor, to isolate where the issue is related to. If external monitor works fine, it might be HW problem with your laptop monitor.
May 01, 2014 | Dell Vostro 1015 Laptop
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
My monitor ia not coming on. How can I get the monitor to work?
How long does it take to shut down? Common causes:
1 You may have an external monitor selected. Hold the function key (might labeled Fn, it's usually near the left shift key) and press F8. If the screen doesn't come back press it again 'cause there are three options (panel, external and both)
2 The screen might be dead. Plug an external monitor in and see if you get a picture. If so repeat step one and check your video settings.
3 The laptop MB might be faulty. No real way for you to test this.
Aug 28, 2012 | Acer Aspire 5100 Notebook
HOW TO REMOVE SCREEN FROM DELL VOSTRO 1000 AND CONNECT TO A MONITOR
if laptop is still running with a broken LCD screen , it id possible to use an external monitor, if laptop totally died or broken, not possible to use with external monitor.
Mar 26, 2012 | Dell Computers & Internet
How to increase volume in dell vostro 1014
Hi
i have heard that this may help but i cannot verifi it
so please let us know if it works
ctrl n up arrow
many thanks
on a lot of laptops it is FN+arrow up key
Aug 18, 2011 | Dell Vostro 1014 Laptop Computer
Hi ! i have dell vostro 1510 and which is not booting up. even the bios is not showing up. Black screen appears and the loading lights blinks for 4-5 times then nothing happens. Power button is glowing...
- try to plug an external monitor on your laptop
- if you can see a screen on the external monitor, then you have a faulty LCD
- if you don't see anything on the external monitor, then you have a faulty motherboard
Jul 04, 2011 | Computers & Internet
How to boost volume dell laptops
My fix on Vostro 3700 was to go to the speaker/headphone properties, under the Enhancements tab, i turned on Loudness Equalization. My volume was louder than ever before
May 04, 2010 | Dell Vostro 1014 Laptop Computer
Dual monitor will not work
Well, my friend. The issue is, the dual monitor hast THREE modes:
1. Internal monitor only
2. External monitor only, and
3. Both monitor simultaneusly.
You may need to keep pressing the FN combination until you reach the mode you want. (You need to wait about 3 seconds before the mode can be observed)
Jul 09, 2009 | Dell Vostro 1500 Notebook
Laptop screen has vertical black and white stripes
when you hook up the external monitor did you hit the fn key and f5 this should turn on the external monitor port
Apr 12, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1700 Notebook Logo
98 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
