Question about Sharp LC-32SB24U 32 in. LCD TV
The TV does not respond to the remote control. I have replaced the batteries in the remote control
  • 2 more comments
  • I can't imagine how this works without power to either unit but it was a quick and easy fix that I could do myself. Thank you so much for posting this advice. I'm going to print it and save it with the tv receipt ... just in case. :-)
  • Bill Sep 22, 2013
    Unreal. 9/22/13. Yes, reboot the tv. Now I have two remotes that work. Even the new remote did not work until I did this procedure.
  • Bill Sep 22, 2013
    And. The old remote was NOT producing the light in the camera test. Yes, new battetr
  • Bill Sep 22, 2013
    I even tested the old remote in a totally dark room. Unreal.
  • Sharp Master
  • 736 Answers
You have to unplug the television after turning it off. Take the batteries out of the remote control. Point the remote toward the remote sensor (bottom right hand corner of the television set). Press the power button on the remote control and hold it down for 30 full seconds. Next press and release every button on the remote control. Next plug the tv back in and power it on from the power button on the television itself. Replace the batteries. Adjust the volume using the remote control. If that works the problem is solved. If it doesn't work you may need a software update, a new remote control, or repair to the sensor on your television.
To see if your remote control is working look at it through the viewscreen of a digital camera. The digital camera must be turned on and ready to take a picture. Next press a channel button on the remote control. Do you see a bluish white light? If so the remote control is ok.
Posted on May 11, 2010
Testimonial: "Wonderful. It fixed the problem. Thanks so much!!"
  • 9 more comments
  • Wazzu Nov 05, 2010
    At first I thought there was no way this would work without power in either the remote or T.V. After more research I finally decided it wouldn't hurt to try. Believe it or not it worked. Never again will I question advice even when it sound rediculous. Thanks
  • ufferheide Nov 27, 2010
    It fixed the problem. Thanks.
  • ronrob8978 Dec 26, 2010
    The problem is resolved! I was skeptical but family (and football playoffs) persuaded me to try it. Thanks VERY much!
  • skeptile Dec 30, 2010
    Unbelievable. I don't know what voodoo you're purveying but it is some darn fine voodoo! It would be interesting to know WHY this works.
  • scoobykitty
    scoobykitty Sep 18, 2012
    This worked awsome!!
  • zack_pitsch
    zack_pitsch Oct 25, 2012
    Amazed. did this before i ordered the remote sensor and it worked! crazy!
  • Carl Touchie Dec 22, 2012
    This worked after trying a second time...awesome
  • Vance Jan 28, 2013
    Can't believe it but it worked, thanks!
  • Shreenaveen Aug 24, 2013
    This worked like magic.... Thanks a ton
  • mbryan6434 Apr 28, 2014
    Unbelievably; it did work. Thanks
  • Loretta Northcutt
    Loretta Northcutt Apr 28, 2014
    You're welcome everyone!
2 Suggested Answers
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
I got a replacement remote for the TV but it doesn't work on the TV. How do I get it to function with the TV
When you say "Replacement" you do not say if you bought an "Original type" replacement or one of those Universal ones which may or may not have the correct codes for the TV in question. Not all Universals have ALL POSSIBLE CODES.
You have two options.
1. Have your TV checked to find out if it is capable of responding to a remote control. If it won't then no remote whatsoever will make it respond ! Remote Receiving circuits fail as well !
2. If it is OK in that regard, get an original brand replacement Remote Control.
You can buy a Remote Control tester or you can take it to a TV technician who can check for you if the Remote is working.
Be sure to double check that you are using NEW batteries and that they are put into the remote with battery polarity as marked. You would be amazed how many times I have found that the problem was caused by persons putting batteries in the wrong way round !
Because of the shape of the ends of them, with some rechargeable batteries it is not so immediately obvious at to which is + and which is - unless you look very closely at the battery markings.
Jul 08, 2015 | Mintek DTV-323 32 in. LCD TV/DVD Combo
The tv does not responding with the remote control
Remove the battery from the remote.Wait at least 30 minutes. ZReinstall the battery and start over. You will need to reprogram the remote.
Jun 10, 2015 | Universal Remote Control Televison & Video
Why is my JVC TV not responding to working remote?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Dec 17, 2014 | JVC Televison & Video
Philips TV not responding to remote
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. Ome among its posts have details about it. Surf the site in "Mosaic" view. It will make surf easier.
If remote control is found OK, check and replace the infrared sensor inside the TV.
Mar 19, 2014 | Philips Televison & Video
Remote control slow to respond to Bush tv (LT42M1CFA)
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Aug 15, 2012 | Big Button TV Universal Remote
TV isn't responding to the remote
Hello, sorry to hear that you having issues with your remote or TV.
First, comes the most common questions but its worth a shot, Did you replace the batteries?
Second, You could try and clean the infrared eye on the tv with a moist cloth to make sure the window on it is not dirty or blocked from the line of sight of the remote.
Also check you batteries once more, also take the batteries out of the remote and push on the buttons as one ore more could be stuck causing the remote to malfunction.
Worse cases are bad remote or bad control board in the TV witch cause it not to respond to the remote. First check the remote very well. You could also replace the remote at www.remotes.com or purchase a universal remote as well.
Only if the new remotes do not work you would call it a bad control board in the tv witch could cost around $90 to replace if there are part available.
Most cases would be the remotes batteries or connectors itself or batteries incorrectly installed.
Thanks for using Fixya.com
Regards
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 14, 2011 | Sylvania 6419TD 19" TV
Panasonic DVD player not responding to remote control
Press enter and 1 on the r/c together for more than 3secs
Oct 17, 2009 | Panasonic DMRES15 DVD Recorder
TV will not respond to remote any longer.
have you replaced the battery ?. If so the remote may be faulty. there are buttons on the tv that will do all the remote can.
Nov 30, 2017 | GE RM24909 Remote Control
Sharp LC-32SB24U 32 in. LCD TV Logo
2,992 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
