Question about Westinghouse LCM-22w2 Television
I want to connect just a basic cable line into my television, but when i do there is no picture or sound. i know the cable is good because it works on my roommates tube television in the living room. how can i get the picture and sound to appear on just a basic cable line (no box)?
    Problem Solver:
  • 5 Answers
Are you trying to hook it up for the purpose of watching cable tv? Because if so I am not sure that you will be able to hook it up directly without a box considering it probably doesn't have digital capabilities. You might try getting a converter box and try it then. Or it could be something as simple as changing the input on your screen. On this monitor in particular I believe it is one of the top buttons on the right back side of the monitor.
Posted on Sep 23, 2010
  • nrmii Jul 02, 2011
    unless you use a cable box it won't work. Although it is digital capable, it doesn't have a tuner.
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Panasonic 32LX70, I have basic cable and the sound
I have the same issue. Its not the cable because all the other tv's are fine when tuned to those channels....Any luck?
Mar 08, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
How can I have sound but no picture for a MXNX 42VI?
Make sure the video cable is firmly connected to the TV. you should have a red & white cable for the sound (which at least one is obviously plugged in and working), and at least one other cable for the video. Without knowing what video source you are using, I can't tell you exactly how to plug it in, but basically just check all your connections. If they're all there, jiggle them a bit and push them in firmly.
Sep 13, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Tosheba 50hx81 no picture or sound. press on button and hear speakers do something but no sound
It is likely that you don't have the right input to the television.
First get a source that you know works. How about a DVD player.
Get the cables from your DVD player (should be yellow RCA or "Phono" plug for the composite video out put.) Connect only the yellow video out put to your t.v. input and then press the av input button until you see the picture (note: besure that the DVD player is turned on and you have a dvd in it. We sometimes miss the very basics).
Once you get the picture than connect the audio cables, should be red and white to the corresponding colors. Do you have audio now?
If this test worked fine, it is likely that the solution to your other problem is that you have it on the wrong av input and need to press that button a few more times to find your satallite or cable input. There is a possibility that you are trying to use the tuner in your T.V. and it may be again as simple as choosing antenna input and that too needs to be hooked up to a good source.
Write me back if none of this helped.
Dec 16, 2008 | Toshiba 50HX81 50" Rear Projection...
New straight out of the box, TV no picture and no sound
If this is working in another room I suggest you check the connection from wherever that particular wire comes from ex. splitter or directle from the antenna I do not know where you tapped in that line. I hope this helps you out.
Nov 28, 2008 | GPX KCL8806DT 7 in. Portable Television
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Jan 16, 2008 | Televison & Video
Bad Cable Input
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Oct 17, 2006 | Polaroid FLM-2632 Television
No picture
Please let us know more details next time, like what you have tried already. Try connecting your screen directly to a DVD player or other alternative source to make sure the problem isn't with the source, maybe you were watching cable TV and the connection is slightly loose - Try playing with all the connections, pulling them a little out or pushing in, blowing into them, replacing cables, Try connecting another screen. at the moment its hard to tell what went wrong. Does the sound come from the plasmas speakers, or from a home theatre setup? If you couldnt work it out with the very basic solutions listed above please repost your original question with as much relevant detail as possible. Good luck
Mar 18, 2006 | Orion PM4042 42 in. Plasma Television
Westinghouse LCM-22w2 Television Logo
111 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
