Question about Motorola Talkabout T5620 (7 Channels) 2-Way Radio
One of my model T5620 Talk About radios has suddenly lost the "signal" icon and it " button is pressed. The battery icon indicates that the battery is fully charged. Can you help? Thank you.
  • 1,555 Answers
To me it seems someone sat on it. Your keyboard might be fried or may be still alive. You need to push each and every key forcely and release in flash or you may need to open it up and then check the status. The keyboard is the prob as of now.
Posted on May 01, 2010
Every time I press the talk button the radios show low battery icon and I'm not able to transmit on either radio. How can I rectify this problem?
Are you SURE that your batteries are up to snuff? I.E. when they have a light current load on them they are ok but as soon as you try to increase that current load they die off quickly. With two-way radios, the actual current drain depends on whether you are transmitting or in standby (receive) mode. Transmitting requires significantly more current than standby mode. So, I would look at what kind of batteries you are using. If they are a good name brand alkaline, check to see if they measure close to 1.5 volts with a voltmeter or check them with a battery tester to ensure they are good. If they are ni-cad or ni-mh rechargeable batteries, make sure they are rated at least 1200 mah (milliamp hour). I use Sanyo eneloop rechargeable batteries. They last a long time for me. One other thing, make sure your battery compartment is clean and there is no corrosion on the contacts the batteries are placed into.
Hope this helps,
Jim
Sep 08, 2014 | Uniden Radio Communications
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Hello I have a Angelcare baby monitor model ac1100 and have had it 1& half years it hasn't put a foot wrong and all of a sudden the tv monitor side of it is not working properly! It stays a blue screen and...
If you can only see two lines appearing on the screen this may indicate that the parent unit is searching for a signal from its partner and cannot locate one. Check that the nursery unit has fresh batteries and is switched on. If all ok with the nursery unit you may need to "re-pair" the two units together as per instructions. Note that the maximum distance between the Parent Unit and the Nursery Unit is approx. 100 metres indoors. In reality the Signal Strength Indicator on the parent unit should show the strength of signal between the Parent Unit and Nursery Unit. The Out of Range Indicator should alarm when the two units have lost connection and the Out of Range Icon will be visible in the Parent Unit screen. However these units sometimes require a "re-pairing" exercise to get them to communicate with each other again. Ensure both units have fresh batteries.
HOW TO RECONNECT THE PARENT AND NURSERY UNIT
In the unlikely event that the connection between the Nursery Unit and the Parents Unit is completely lost, please follow these steps to restore the connection:
1. Turn both the Parents Unit and the Nursery Unit OFF
2. Turn the Nursery Unit ON
3. Press and release the left wing 4 times. The nightlight will fl ash.
4. Turn the Parent Unit ON. A blue screen will appear with the NO SIGNAL icon in the Parent Unit Settings Bar
5. While pressing the TALK BACK button on the right hand side of the Parent Unit, press and release the POWER button on the left hand side of the Parent Unit
6. If successful, the video capture will appear on the Parent Unit's screen again. The connection was successfully restored
Jan 18, 2014 | Baby Gear
Cobra frs 132 talk button not woking
The first radio has the transmit code set improperly.
Dec 15, 2012 | Cobra Radio Communications
Why does my motorola talkabout turns off when I try to radio someone
That's what they call the roger beep It is there so that you wont say roger every time to signal the other side's turn to talk.
You can press MENU button, press once more until you can see the music(note) icon or the word 'Roger'. Select ON or OFF using UP/DOWN key. Press MENU to save.
Car Transimissions
Jun 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
Hello, this is a long shot, but thought I would try. I have a pair of Motorola t5620 that have worked great up until now. I have everything set the same on both units. Channel 3-1 one has a display beside...
I looked in the user guide of some other TalkAbout models and found the emblem you are describing. I believe it is the volume control emblem. Here is a link where you can look for yourself http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T6200_User_Manual_E.pdf see page 24.
You might have one of three problems:
1) The volume potentiometer is going bad in one of the radios. If this is the case, you may be able to find a sweet spot where it will work. Try moving the volume knob to different settings and see if you can get it to work.
2) Something is wrong with your PL code setting, VOX setting, or another setting on the radio. Go back to square one, and reprogram the radio for simple operation with no special features turned on. Then try using the radios together. If you still cannot communicate, one of your radios is bad and the only way to tell is to introduce another known good radio into the mix.
3) The radio which will not transmit might have a bad battery. It takes more energy to Transmit than to Receive. Try swapping the batteries and see if the problem moves to the other radio. If so, replace your battery.
Here is a link to the T5620 user guide, just in case someone reading this needs it: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Aug 04, 2011 | Motorola Talkabout T5620 (7 Channels)...
Hey Guys, I have two T5620 Talkabouts one will not brodcast. Is there anything I can do or anywhere to sends them to have them repaired? A.
Sorry, the T5620 is a disposable/ non-repairable radio. You might try checking to see if your battery pack has failed. Switch a known good battery into the radio and see if it solves the problem. Also, clean your battery contacts on the charger/radio and battery with a pencil eraser to insure you are getting a good charge.
Aug 10, 2009 | Motorola Talkabout T5620 (7 Channels)...
One radio not working
Hi it sounds to me that you have a fault in the microphone or the cable to the unit.check all the connections wiggle the mic cable and note any changes.
You say the mike button is frozen? try adrop of CRC in the press to talk switch-- only a drop or two, dont want it getting into the microphone it self.
Oh and have you got the batteries in the right way?
Cherrio John
Apr 04, 2009 | GPX FRS200 (14 Channels) 2-Way Radio
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Moto T5620 Buzz
check if that radio has the QT feature eneable, be sure that you are not making any feedback when you press the ptt. If one of the radios could have a problem be sure if the Buzz is transmited or received for the radios
Jan 24, 2007 | Motorola Talkabout T5620 (7 Channels)...
Motorola Talkabout T5620 (7 Channels) 2-Way Radio Logo
128 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
