Question about Philips GoGear Flash MP3 Player
What does it mean when it doesn't turn on - Philips GoGear Flash MP3 Player
  • nintendo_15y May 01, 2010
    ok it doesn't seem that its broken but when i plug it in to the pc and all it said is that the hub power is over the limit???????
The battery is old or broken . buy a new battery.
Posted on May 01, 2010
2000 cadillac deville driver side won't open with the key
1) Key turns but dose not unlock door. This means that the rod that goes to the back of the lock has came off. This also means that is the reason door is not unlocking with the remote as it pops the lock rod inside the door which pushes the lock open.
2) Key does not turn lock at all but works passengers side door. This means that the locks has been changed in the door, but that doesn't sound like the problem as you say the remote doesn't open the drivers side door so more than likely the rod has came off the back of the lock
Nov 07, 2012 | Cars & Trucks
Why does my tablet when i turn it on it has a battery sign with an explanation mark inside it and will not turn on
The exclamation mark means that your tablet has no battery left. You should try plugging your tablet in for a few hours before turning it on (if it doesn't turn on by itself.) If that doesn't work and you still see the exclamation mark, I suggest that you ensure the charger is properly plugged in to the socket and that its properly attached to the tablet.
Sep 05, 2012 | Tablets & eReaders
Acer travelmate 8472 not switching on
Take out the battery and hook up the AC Adapter to it. Hook up the adapter to a working outlet. If the laptop still doesn't turn on then try another working AC Adapter. If the laptop doesn't turn on at this point then that means the motheboard is bad and would need to be replaced.
Feb 05, 2012 | Acer Computers & Internet
Engine wont turn over on my gv 2006
The 1st thing i need to do is clarify what you mean by "won't trun over" do you mean the starter motor spins the engine and it will not fire up or that the starter doesn't trun the engine over? If the starter doesn't turn the engine over do you hear a clicking coming from the starter solenoid when this happens? If so replace the starter solenoid the heavy electrical contacts are burned.
Dec 28, 2011 | 2006 Suzuki Grand Vitara
Electronic fuel pump doesn't alway run when you turn on the ignition
That only means the pressure is still within range,so it doesn't have to run until injectors let fuel thru into engine and it fires up.
What problem are you having,that makes you think it has a fuel problem.Be specific,please? don-ohio (:^)
Nov 11, 2011 | 2000 Mercury Grand Marquis
What to do when iphone doesn't turn on
If it won't turn on. Meaning it doesn't turn on turn on. The phone is dead and gone.
If the phone turns on but sticks at the apple logo, that means it needs a restore/update.
If the phone turns on and stick at the usb/apple logos. That means it needs to be restored.
To restore or update. You need to use itunes. If the phone is bricked and dead, dead... Then you need to get a new phone
Sep 11, 2011 | Apple iPhone Smartphone
It doesn't allow me to take a shot. On a lense itself, there are two settings A and M. When it it is on M it takes a blurry shot, but on A setting doesn't allow. Please, help me.
M means Manual Focus. If you set the lens to this then you need to turn the lens manually to get it into focus.
A means Auto Focus and when the lens is det to this it should focus automatically but you need to set the mode button OFF Manual. It should work on any other setting.
Jul 05, 2011 | Cameras
Lcd screen is flickering on and off very fast
Disconnect the lcd from the computer. Turn on the LCD and see if it still flickers fast. If it doesn't then go ahead reconnect the lcd back to the computer. If its still flickering, then go ahead and hook it up to another laptop or desktop. If it doesn't flicker on another computer then that means there is a problems with the video card on the original computer.
If it still flickers then that means the lcd is bad and would need to be replaced.
May 31, 2011 | LG L1960TR 19" LCD Monitor
The 4x4 light is blinking off and on
Typically this means that the truck is trying to engage 4wd, and can't. moving slightly should allow it to. If it doesn't, you have a problem.
Some models will flash the 4x4 light when you are in 4wd low. I am assuming it is a new thing, so this probably doesn't apply.
Turn your wheel fully to one side, and if it doesn't "grab" as you move, your 4wd is not functioning, and you need to take it to a mechanic, or grab a service manual, depending on your skill.
May 07, 2011 | 2006 Ford Escape
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
Philips GoGear Flash MP3 Player Logo
77 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
