Question about Canon EOS 40D Digital Camera
I am using Nikon AI lenses on Canon 5D. Results
I am using Nikon AI lenses on Canon 40D. Results are stunnig. How can I correct abrasions with software?
  • kakima May 11, 2010
    Abrasions are a hardware problem and will need a hardware solution, like very fine sandpaper.
    If you mean aberrations (chromatic or otherwise), then that depends on the software you're using. Would you care to specify, or are you asking for recommendations?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Jun 04, 2010
Which lens fit nikon d5001
To the best of my knowledge, most, if not all, Sigma lenses fit most cameras that use interchangeable lenses with the appropriate adapter. As I recall, Sigma uses a bayonet mount and adapters are available for many name brand cameras. For example, I have a Nikon and my Sigma 600mm came with an adapter for a Canon. All I had to do was order a Nikon adapter. If you're not sure, you might want to check with a local camera store to confirm which adapter you need.
Jun 17, 2014 | Sigma Super Telephoto 600mm f/8.0 Mirror...
User Manual
I checked the Tamron website menu of manuals and one is not listed. This is a pass-thru device, so other than placing it between your lens and camera body, there should be no additional settings. Your camera focus and exposure is thru the lens so the camera should adjust seemlessly. Please tell us what the problem is, what lenses and body you are using.
Mar 07, 2014 | Tamron F Af Tele-converter 2x C-af1 Bbar...
Will this lens work with a Canon 5d mkii?
Quantaray makes their lenses with a variety of camera mounts. A lens with a Nikon mount, for example, will not work on a Canon body. As long as you get the lens with a Canon mount, it will work with the 5D MKII.
Mar 09, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Compatible nikkor lenses for nikon f 55
Almost all Nikon-mount lenses made in the past half-century will work on the F55. With old lenses, you need to make sure they're AI or adapted to AI. Among newer lenses, you don't want to use the DX lenses designed specifically for digital cameras. DX lenses will work, but you will get vignetting (dark shadows in the corners). You will also lose the autofocusing capability with AF-S lenses.
Jan 24, 2011 | Cameras
Will the sigma 75-300mm 1.4 5.6 fit in a nikon d80
Assuming the lens has a Nikon mount, yes.
Sigma makes lenses for a variety of cameras. Different manufacturers use different lens mounts, and they are not interoperable. A lens with a Canon mount will not fit onto a Nikon body, for example.
Nov 16, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
I have a Canon 100mm macro lens used on a Canon EOS 40D Camera. The problem I have is that the images produced seem to be not pin sharp, even when using a tripod and the mirror lockup function on the...
It seems that you have either a faulty lens or one which is performing outside of the minimum quality standards. You have clearly done everything possible to try and eliminate all other causes. Looking at the firmware updates for your camera, none of them mention an issue involving your lens but you may wish to ensure that you have the latest firmware anyway.
All you can do is to contact Canon customer care to request that the lens is exchanged.
Sep 07, 2010 | Canon 100mm f/2.8 Macro USM EF Lens
Canon 5D and canon 40D are they type A or type B cameras as per 380 EX manual
Hi Bruce,
You have the latest cameras and they will work with ETTL II with Canon 430EX/550EX/580EX and 580EX II. Earlier models use ETTL and films use TTL.
Hope they are helpful.
atdlee@netzero.com
Jan 13, 2010 | Canon EOS 40D Digital Camera
Camera lens
Hey kgconstruct,
The lens description that your posting is categorized under is a 75-300 f/4-506 DL lens for Nikon AI. If this is correct then no this lens won't work on a Canon camera. I am assuming this isn't correct and the lens you have is for a Canon camera, and if this is true this lens should work on the XTI. If you’re thinking of buying this lens I would go to a local camera store that carries this Sigma lens and try it out first to make sure you like it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 16, 2008 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Old Lense and new camera
Here is a link to the lens limitations of the D40, same for the D40X:
http://www.popphoto.com/photonews/3543/update-to-nikon-d40-hands-on.html
The camera will not recognize the lens but you can take pictures setting speed and aperture manually. Since you see results after you take the picture, you can make adjustments to correct your exposure
Dec 24, 2007 | Cameras
Canon EOS 40D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
