Question about Remington Electric Chain Saw
My adjusting block is worn, can I purchase a new one?
    President:
  • 2,220 Answers
It depends on which saw you have. Are you aware they are no longer in production? Eventually a replacement part will not be available.
You do not give us the model number of your saw to verify this will fit.
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
• Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
• Click the "YourModelNumber" - Remington Electric Chain Saw "View Model" link.
• Click "View Owners Manual" or "View Illustrated Parts Diagram" link.
• Type "YourPartNumber" into the "Search for your parts by Part #:" window, then click search.
A tension repair kit is available here:
MasterParts.com
http://www.masterparts.net/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MPD&Product_Code=108640-MD
Part number 108640-MD; DESA SPECIALTY PARTS: KIT, ADJUSTMENT SCREW FOR SPROCKET COVER (REM-18); $5.95.
Kit fits the following covers: 108640-01, 116675-01 and 108641-02 (note: for the 108641-02 the screw will adjust from the front with a screw driver, not with a thumb screw at the back) KIT INCLUDES: screw, clip & adjustment block. If not available here please reply (below) with that information. TIA
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Posted on May 02, 2010
How do you keep the sanding belt on the machine
on the frontside there MUST be is an adjusting knob to adjust the good line but if there are problems by a dry dirth or cases machine or worn bushings there can be a problem with that. if the adjuster is missing then you have a problem
Nov 13, 2015 | Tools & Hardware - Others
Ryobi cs 3635 manual
clean the bar groove and also the bottom of your teeth may be worn too but there is usually an adjustment screw in the bottom of most saws
Aug 17, 2014 | Garden
How to adjust door viking dfsb423
Viking 42" built-in units usually don't offer any door adjustments. If one of the doors are not closing well, check for obstructions blocking the door bins, worn door gasket, and possible door warp-age on the panel ready models. Viking did have top hinge recalls updating to the new "Cobra" hinge on many of their models which can be verified by calling viking and providing your full model/serial numbers. If your Fridge door is lower than the freezer door you most likely have a worn door closer located on the lower hinge of the fridge door, the closer is a 2 piece plastic interlocking/mating unit which wears down over time from friction. This usually needs to be replaced. Pleazer Appliance...
May 06, 2014 | Viking DFSB423 Side by Side Refrigerator
2004 Buick Lesabre blower motor repair
You dont.
Replace the motor.
Buy a good one at Napa or Autozone. Dont buy advance because they have poor quality electrical parts in my experience.
Install new motor. Done.
Mar 14, 2014 | 2004 Buick LeSabre
How do i get squeaking door to stop kenmore
Can you be more specific with the description? Where? Top? Bottom?The best solution is to identify if the alignment is correct. If the alignment is good, look at the hinges for excess wear. If there is no sign of the hinges being worn, needing replaced; apply some light oil, "Three in One Household Oil". This will only take 1 or 2 drops in the pivot point of the hinge. If the alignment needs adjusted the hinges will need moved. You will need the tool (whatever is used by the manufacturer) and something to block the door. Purchase new hinges if they show wear. Loosen or replace the hinges, position the door in the desired position, tighten the hinges securely, careful not to strip out the threads. Check the door function and alignment make adjustments as needed.
Mar 16, 2013 | managemylife.com
3 handle shower - handles tap/ block each other
It sounds like you have the wrong handles for this faucet assembly. Did you recently purchase new handles?
Jan 17, 2013 | Price Pfister 01-81BC Savannah 3 Handle...
Some of the rocker arms are chattering on my 1995 pathfinder SE 3.0liter V6 4X4 i need to know exact specifications on tightening them back! PLEASE HELP!
This engine and vehicle are fitted with hydraulic valve adjusters which means there is no clearance adjustments for them.
The trouble will be the lifters are either worn or have a blocked lubricating orifice.
Give it an engine flush and put in some new engine oil, this may help you out.
Thanks
Jason
Oct 05, 2010 | 1995 Nissan Pathfinder
Why doesnt my chain tighting screw tighten the chain?
The side cover mounting nuts must be loosened to allow the bar to move. If still no action from the adjuster, likely the small 'tang' that projects from the adjuster 'traveling nut/block' has been broken off. Remove the drive cover after releasing the chain brake. Turning the adjustment screw causes the block/nut to move along the screw and the tang pokes into one of the large holes in the drive end of the bar carrying the bar with it. Purchase a new part, or have a new tang welded onto the existing part. Hope this helps!
Jun 23, 2010 | Garden
I purchased a GE SS 22.5 CF Refrig. The doors do
usualy there isnt a height adjustment most common problem is worn door cam due to over weighting door the door cam is made from hard plastic and is known to wear out even break
Mar 01, 2009 | LG LRFD25850 Stainless Steel French Door...
Remington Electric Chain Saw  Logo
148 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
