Question about Samsung Digimax L60 Digital Camera
The lens is stuck and probably has sand in the gears, as I recently took a beach vacation. How do I get down to the engine compartment?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 01, 2010
When I turn the camera on a red light goes on in the bottom right back of camera and it turns off. Battery is charged.
my question is significant; alencender camera or lens comes out stuck giving
is possible that the lens barrel is filled with sand if you took her to the beach once
Oct 02, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
I am getting a lens error message. i was at the beach at am concerned a little bit of sand may be in there!
Lens probably does not extend or retract because the sand got stuck in gear box. The lens can in about 50% of the cases be repaired without having to replace it by opening it and cleaning it out. Try to return to manufacturer first. If you're out of warranty, there are third party places that fix them such as camera lens repairs. If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay. Opening an cleaning requires special equpiment, but you can just replace the whole lens, it's usually a $30 part.
Jul 01, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Automatic lens cover does not fully open
1. there's a problem inside of the camera especially the gear if the camera fell down or applying excessive force to the lens part. The gear was broken thats why it was not fully open and having weird noise inside.
2 if you went out to the beach or place a lot of dust.possible the sand or dust goes indide of the lens gear and cause of stuck up and not fully open the lens.sometimes becuase of this the gear was damage or broken and you need to bring to service center.
Jun 03, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Tz2 panasonic lens cover repair
I had a camera with this problem once - a friend took some photos at the beach and filled it with sand!
Try obtaining some compressed air and blasing it out.
A little WD40 (directed with care) should get that lens cover closing nicely, provided there is no debris.
Jul 08, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
I think I have sand in my casio casing. The pictures are sometimes blury and the zoom doesnt always go in and out. We took it to the beach, and well...... Is a Casio Elilim ex-s600. Do you know how I...
You will not be able to clean out the sand yourself. The sand probably got in to the mechanics of the lens and other moving parts.
The inside of the lens is made like a watch, and is very precision for calibration. Once you open up your camera and especialy the lens, I have doubts it will ever work again!
Servicing the camera may not be cost effective. You can enquire to Casio to see what they would charge for this type of service. I would think it would be more feasible to replace the camera.
If you want to take a camera to a beach, make sure it is in a sealed containment. The water vapour, any salt spray, sand, and or sand dust will certainly cause damage to even the most expensive cameras!
Jerry G.
Jul 01, 2008 | Cameras
Sand in camera
no need to take apart just power up and gently pull the lens out and vaccuum the sand out, camera now works perfectly
Nov 09, 2007 | Casio Exilim EX-Z57 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Lens/ resolution problem
I you have been on a beach there are chances that your camera get get sand inside. you have to get it cleaned before use. to not try to operate the camera in the same condition.
Sep 15, 2006 | Sony Cyber-shot DSC-W70 Digital Camera
Samsung Digimax L60 Digital Camera Logo
165 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
