Question about Weber Genesis E-320 Propane Grill
One side seems clogged, no propane gets through.
One side seems clogged, no propane gets through. Do I need to have someone come to fix this or is there something I can do?
    Guru:
  • 1,051 Answers
More than likely you can fix it yourself. Remove the burner that's not working or if the burners are joined remove the entire burner unit. Check small holes around edge og burner for anything that may be clogging them. I've used a round toothpick or a small nail to poke each hole gently to make sure it's clear. replace the burner and try agin, it should work fine. In the worst case the burner needs replacing. This can also be done yourself. Purchase the burner from a large hardware store or contact Weber for a replacement.
Posted on May 02, 2010
Weber genesis S 320: Most BBQs have a hole in the side to run the propane line from the tank in the cart to the burner insert. The side panels on this seem to have no hole. Perhaps a small space right at...
Your correct. As looking at it, the right side panel has a hole just larger in Dia than the Regulator to fit thru. Feed it through to the inside of your cabinet and connect. There is also a Propane indicator that I haven't hooked up yet. Enjoy.
Aug 31, 2010 | Weber Genesis S-320 Propane Grill
Propane clogged
It could be a blockage, which means taking the grill apart. But I would try replacing the regulator and hose first, easy to do and not very expensive. If this doesn't work, please let me know.
Jul 08, 2010 | Weber Genesis Silver B Grill
Gas does not come out from burners...It seems
Blow it out with compressed air (canned air - air compressor or blow it out with the back side of a vacuum cleaner. Spiders love the smell of propane gas.
You do have fuel ... right? and the valve is on ... right?
May 30, 2010 | Frontier Gas Grill
Weak flame on webber q200 grill
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Feb 25, 2010 | Weber Q200
Very little gas getting to burners Full bottle of propane Acts the same way as when the propane bottle is getting empty This grill is only about 6 months old
You either have clogged burners and they need to be cleaned. Clogged inlet line to the burners. (This can come from trash, spiderwebs etc in the connection, kinked line etc.) or the regulator is malfunctioning.
Aug 24, 2009 | Weber Genesis E-310 Gas Grill
Fridge & Freezer smell like a gas grille...
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Jul 30, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Won't get cold anymore
Good thinking... you need to hire a service technician (a good one!). Too many jackasses think they know these systems. Obviously, there's something wrong with the system.. if so, you need someone who knows what they're working on/with.
May 26, 2009 | Dometic RM2193 Compact Refrigerator With...
Will light on propanr,but if blows out,will not
Here is a link to parts service and PDF of this model. If yours is a propane model then you may need to contact the numbers on the PDF If you need to download Adobe go to adobe.com and dowload the free adobe 10
http://www.gas-refrigerators.com/pdf/RM2852-parts.pdf
May 12, 2009 | Dometic RM2852 Refrigerator
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Converting LG gas dryer to propane DLE7177WM/DLG188WM
call your propane dealer and they should have someone to convert it to LP for you and yes that sounds to high / larry
Dec 01, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Weber Genesis E-320  Propane Grill Logo
263 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
