Ecler HAK 310 DJ Mixer
Theres no sound coming from the output at all. the mixer powers on and registers an audio input (meters light up etc) but no sound at all. it is deffo not wires connections it deffo is the internal workings of mixer. I just want to know which part has malfunctioned/blown and if it is worth fixing or not and if i could do it myself
SOURCE: behringer mixer UB 1622 fx pro
I've seen inside these mixers (euroracks) and they have a recurring problem.
Next to each op-amp there are small decoupling caps from the power supply rails to ground. These caps, due to 'cost constraints' have 1 volt of headroom- the rails are at 15 volts and the caps rated 16v.
This means they have about a 65% chance of failure.
Also, the psu. is connected via a connector. If you disconnect this and see if the psu powers up with a meter you can figure out if the psu is broken or if the circuit board is 'dragging it down'.
Hope that helps.
Bernie
Posted on May 28, 2008
  • 905 Answers
SOURCE: leem m86t power mixer amplifier
probably blew the amps or the pre amp section
Posted on Oct 08, 2008
mighty thor
  • 51 Answers
SOURCE: Channel mixer problem- No channel B output.
I assume you looked at the pan assignments.
what kind of mixer is this?
Posted on Dec 02, 2008
djproaudio
  • 515 Answers
SOURCE: Pioneer DJM-600 black Professional DJ power on but not working!!
So you get power to the unit, but no sound coming out? How about through the headphones, do you get sound coming out of the headphones?
Are all the volumes and gains raised up? All the eq's are up? Check the back of the mixer, there is a master gain volume - where the connections are - make sure this is up also.
If nothing, then you'll need professional help at this point.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Posted on Dec 18, 2008
  • 153 Answers
SOURCE: Behringer SL3242 Mixer has a noise problem.
It sounds like you have ground loops. This is noise generated by having interconnected equipment grounded at different physical locations. Especially a problem if you have a cable from your cable TV provider connected into your equipment.
Remove EVERY connection into and out of the mixer. Plug in headphones. Noise? If so, mixer needs repair. If not, re-connect equipment 1 piece at a time and assess for noise. If it slowly increases as you add connections you will need expert on-site help to fix it. If it is sudden, what was just connected is the source and steps need to be taken to lift the ground on the connection to that equipment.
Posted on Apr 21, 2009
No sound on DJM500
So what were you doing in there ???
Probably blew the internal Power Supply or the regulators.
Usually you have three, +15, -15, and +5.
I bet you blew one of the 15s.
The +5 lights up the lights.....
Now you need some savvy and a Multimeter to see if your +/- 15 rails are ok and if not, change the regulators. They should be screwed onto a heat sink.
Good luck !!! Preferably take it to a Tech....
Mar 28, 2015 | Pioneer DJM-500 Pro DJ Mixer - B-Stock
I am not getting sound thur my mixer what could be the problem.
Is there any hum sound? Are the switches set to the proper inputs-phono, line?
Feb 14, 2015 | Numark Im1 2-channel Pro Dj Mixer With...
How to connect behringer xenyx 1204usb mixer to a numark mixtrack pro II dj controller?
you have to tell your dj or studio program which device to use as output, but the dj controller doesn't have an audiocard so now i first have to search myself since my mixers have built in serato and another that annoying native i. No i'm just doing difficult while a numarkx5 stands in front of me and the main outputs go to your mixer and your usb is just for recording , but plug the mixer out in the mixer , main out in your monitors and calibrate the sound, but your studie or dj gear wants to know which channel to use and there fore you need to read the manual of your mixer and behringer. It's easy, but not from here.
Jul 27, 2014 | Behringer Xenyx 1204USB
Why mixer turns on but no sound come out, just a weird interfearance noise any ideas?
Be sure the inputs are OK and the amplifier is also working. It is probably the internal power supply but that is just a best guest.
Jul 22, 2014 | Gemini DJ Gemini PS2 2-Channel Stereo DJ...
Where can i get manual for radio shack SSM-8030 audio mixer?
Does your audio-mixer have "pan" control on each input channel?
Pan the channel from "100%-left" to "100%-right".
What about the main output from the mixer?
Does it feed into a stereo-mixer?
Can you adjust the gain on either the left or right channel?
May 10, 2014 | Audio Players & Recorders
I have a new set up and i need a step by step instruction on how to set up the mixer to the amp and the decks to the mixer/amp
if this is a dj type set up, the mixer should have a main output (RCA or XLR), that is what you connect to the input on the amp, each deck should have RCA outputs, depending on if they are turntables or cd players, plug the turntables into the phono channel inputs on the mixer and if they are cd players, plug them into the line inputs on the mixer
Mar 28, 2011 | Audio Players & Recorders
How do i connect yamaha mixer to pc or yamaha receiver
I am sorry to disagree, but some information in the previous post is INCORRECT. DO NOT connect the output of the mixer to the MIC input. The mixer generates LINE level output that should go to the LINE-IN on the sound card. If you connect the mixer to the mic input, you will damage the sound card. MIC level inputs have an additional amplification stage.
Dan
Mar 09, 2010 | Yamaha Mg102c Stereo Mixer
Pioneer DJM 600 mixer keeps blowing ic 557 fuse on power supply board
I repair DJM 600 for many years. :) The reason for the burning of IC 557 (+8V H 600mA ) is invalid amplifier for headphones!!!
Replace IC 310 and IC 312 (in big mainboard), and replace
IC 557with original fuse 600mA
!!!!!CHECK YOUR HEADPHONES!!!!!! This is the cause burning amps.!!!!!
DJ Iskren
Oct 03, 2009 | Pioneer DJM-600 Silver Professional DJ...
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Oct 15, 2007 | American Audio DCD-PRO310
170 people viewed this question
 Grubhead
Grubhead
